  • July 04, 2025, 11:11:00 AM
Author Topic: What is better than a 40VF on pipe?  (Read 4348 times)
Offline Andrew Tinsley
« on: August 09, 2010, 12:37:03 PM »
Hello Everyone,
  It looks that I may have lost a 40VF that I was going to use on a piped ship. Apart from another 40 or 46 VF, what would be a better bet? Preferably something that isn't too expensive?
Andrew.
BMFA Number 64862
Re: What is better than a 40VF on pipe?
« Reply #1 on: August 09, 2010, 01:13:32 PM »
HI Andrew,
If you do not want to find another VF, then a PA would be great.
Never used a RoJett, but you could try to find any of thesein good used condition.  All are *somewhat* expensive.........
Mongo
« Reply #2 on: August 09, 2010, 01:46:58 PM »
Hello Bill,
  Thought that PAs would figure in any answers! Pity they are a little on the pricey side. I know that you get what you pay for and a PA would outlast most things. The problem is that a PA would probably outlast me!
  The 40 VF is very well documented on a pipe, but it is a bit on the heavy side. I was hoping that there might be something a little less pricey and lighter in weight. I don't have the experience to sort out a cheaper alternative, was hoping to pinch someone Else's hard work!
Andrew.
BMFA Number 64862
« Reply #3 on: August 09, 2010, 01:48:31 PM »
Hello Everyone,
Andrew.
Andrew   did you check with the people there at the address? The tracking number I sent you shows it delivered to the address you ask it to be sent to. I still have the tracking/delivery confirmation papers here if needed.
Let me know if I can help with anything else on the pack.
« Reply #4 on: August 09, 2010, 02:18:54 PM »
Hello everyone,
  No way was I trying to get at Randy ! He shipped to the address I gave him. The fault is all mine. Randy is a real gentleman. He has put up with me and his help and service is second to none.
Andrew.
BMFA Number 64862
Offline Martin Quartim
    • StuntHobby
« Reply #5 on: August 09, 2010, 03:07:28 PM »
Ask Randy about the Enya 32CXL and 61CXRL rear exhaust. I think the 32 will work with the same prop and pipe used with the 40VF. A bit less power but a lot less weight too. The Enya 61CXRL is about the same weight of the 40VF.
Martin
« Reply #6 on: August 09, 2010, 03:57:35 PM »
Hello Everyone,
   Lost?  Like in "misplaced"?
    For the money (~$150) you can't beat the VF. I have run pretty much everything in the range, and the only things *I* like better, overall, are the RO-Jett 61 BSE ("Brett version") set up per my SSW post, and the PA75 ("David Version") set up per our SN article. But I have run almost any of the likely 40-61 systems back-to-back-to-back and while they are all radically different in run characteristics and setup, overall the performance is not grossly different from the VF. The VF does some stuff better, the PA61 does some stuff better, and the RO-Jett does some stuff better. The RO-Jett is closest to a VF - it's like a giant 46VF the way I run it. Now of course, as always, *that's just me*. I know exactly what I want it to do, and can make the RO-Jett do that more easily than the others. That's not a knock on anything else.
   When I go to the NATS, while I now have some RO-Jett backups, I always take a ready-to-run 40VF. If I ever get in trouble I know that is going to work regardless of whatever my problems may have been.
    Of all the current systems available, the only one I would consider switching to is the David PA75 setup. All of the alternatives are considerably more expensive than a VF, but even at $400-ish dollars I consider them a huge bargain. They are all pretty much bulletproof, and you don't really need spare engines or parts. I ran my PA61 for something like 6 years with ZERO maintenance and it was still just fine.   I had to put it in the airplane at the 2003 NATS, after having not run it for a year and a half, and I didn't even have to touch the needle, just cruised along at 5.4 in a thundering 4-stroke.
« Reply #7 on: August 10, 2010, 04:00:01 PM »
How about a Magnum XLS (or ASP square head) .36 with the PTG pipe setup? The pipe is the most expensive part of the setup. The engine is only slightly more $ than the header or prop. Any of Randy's "40" series designs would be good.   y1 Steve
Online Howard Rush
« Reply #8 on: August 11, 2010, 03:02:27 AM »
PTG's been using a VF lately.
« Reply #9 on: August 11, 2010, 08:57:22 AM »
Whats better than a 40 VF ? , TWO 40 VF's !   maybe .Be a fair sized aeroplane .
« Reply #10 on: August 11, 2010, 01:59:02 PM »
Brett,
>>are the RO-Jett 61 BSE ("Brett version") set up per my SSW post<<
Where could this be found on SSW?
On the 40VF, for the money, you won't find any better. I'd just look for another one.
« Reply #11 on: August 11, 2010, 02:20:13 PM »
Hello Everyone,
Andrew.
Andrew
many motors are better than the 40 VF,  the VF 46 for one, also the PA 40 RE  , Merlin RE, OPS 40 RE, HP 40 with side to rear, Kaz Minato says the FSR 40 is better.  The 40 VF is not the best motor that is the opinion of a few people and they are welcome to their opinion, but it is not fact. I have had people also tell me that the MVVS rear 40 was just as good if not better than the 40VF , much the same with people raving about the British made RE 40 Irvine
The 40 isn't even in the same league for power in the comparision with modern 51 61 and 65 RE motors.
Several years back Ted Fancher had a powerful 46 VF in his plane at a hot humid NATs and the VF would not fly the airplane. David talked him into switching a 61 PA and the differance was DRAMATIC. The plane now went thru everything, at the same speed with no problems. The best thing you should do is try to match the motor to the plane that you are going to put it in.
« Reply #12 on: August 11, 2010, 03:05:12 PM »
Brett,
http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=103&topic_id=232053&mesg_id=232053&listing_type=search
  You responded to it, I think.
« Reply #13 on: August 11, 2010, 03:12:47 PM »
   Certainly, which engine is "better" is an opinion, since no one has determined what "better" means.  I have been pretty careful to avoid going down the list of what particular characteristics I think are better or worse about various engines combinations because it is just an opinion, to maintain harmony/avoid directed urination contests.
« Reply #14 on: August 11, 2010, 03:28:59 PM »
Hi Brett
I agree with you about what is "better", many people think all 4 cycle with no hint of a 2 is "better" some run the VF in a screaming 2 cycle so it cannot "windup, still other think a wet 2 cycle all the time is "better", Then again you have the classic 4/2 run that many people will never go away from. I think the thing is to find what type of run suits "you" (the pilot) better and go from there. I have just been informed that side EX motor run better and "all"  RE motors..so there is another " opinion"
Many differant ways to do the same task...run the same engines..
« Reply #15 on: August 12, 2010, 02:39:34 PM »
Hello Randy,
  Don't want to start a slanging match! So I will be brief and state my requirements. 1/ I want to try a piped ship, before I get too ill and decrepit. 2/ I can't handle a large heavy plane, because of a muscle wasting disease, so small it will be! 3/ The only "objection" I have to an OS 40 VF is that it is a heavy engine. I am not keen on extra weight, because of 2/.
  From what has been said, the OS 40 VF sounds good because it is plug and play, this is why I went for the combo in the first place. I was hoping that my post would turn up a similar performace / well known set up, engine that was maybe a bit lighter and hopefully cheaper.
  From what has been said, there are lighter options with well known setups, but they cost more! Looks as though another 40 VF or maybe a 46 VF is still a good compromise (I expect the 46 to be lighter than the 40?!)
Thanks everyone,
Andrew.
BMFA Number 64862
Offline Balsa Butcher
  • High Desert Flier
« Reply #16 on: August 12, 2010, 04:46:25 PM »
Have you considered a PA-40 Ultra Lite?  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #17 on: August 12, 2010, 07:33:19 PM »
Hello Randy,
Thanks everyone,
Andrew.
Hi Andrew
I will keep on the lookout for an inexpensive motor for you, Hopefully we will not have to find one if yours shows up. I also can ship plans straight to you by mail folded in an envelope, but you will need to know what your going to use ..before,, you start
« Reply #18 on: August 13, 2010, 05:15:11 AM »
Hello Randy,
  That is kind of you. Will do a little more digging on the "missing" 40 that may or may not be missing! Will give you a call soon.
Many Thanks,
Andrew.
BMFA Number 64862
Offline Ward Van Duzer
« Reply #19 on: August 25, 2010, 12:39:57 PM »
Economical...Piped...Smallish...Lightweight...engine...
Hello!
Sounds like Thunder (Aero) Tiger .36 to me. And a Randy small .40 pipe. But I'm very prejudiced!
Order one from Dacula, and have Randy wave his magic wand over it!
Lots of .35 / .40 sized airframes around to hang it on.
Ward-O
steven yampolsky
« Reply #20 on: August 25, 2010, 02:39:25 PM »
There was a smaller sibling of the 40VF: 25VF. It can pull a .40 size airframe. Ebay.
Offline Brian Hampton
« Reply #21 on: August 26, 2010, 09:19:51 PM »
There's also the Enya .32 RE and a few hints on the Enya web page about a possible 40RE.
« Reply #22 on: August 26, 2010, 11:15:17 PM »
Hello Randy,
   Sorry to hear of your illness, but one of the other features of the 40VF is that the line tension is not overwhelming, particularly when it gets windy. The tension is light to moderate  - but the same everywhere. That has been a consistent feature in any airplane I put it in, including the airplane I normally fly with a 61. One reason is that you can generally fly a little slower without running out of poop in the verticals.
« Reply #23 on: August 27, 2010, 09:58:09 AM »
The thing is a bit of a boat anchor, but the truth is, you just shorten the nose a bit and move on. And in the grand scheme, the extra couple of ounces don't really make any difference to the overall weight. And it is a plug and play system.
steven yampolsky
« Reply #24 on: August 27, 2010, 02:16:54 PM »
The thing is a bit of a boat anchor, but the truth is, you just shorten the nose a bit and move on. And in the grand scheme, the extra couple of ounces don't really make any difference to the overall Member in good standing of P.I.S.T
So why are you so P.I.S.T.?   LL~ LL~ LL~ LL~ LL~
« Reply #25 on: August 28, 2010, 12:34:08 PM »
Brett,
  Thank you for the information on the line tension issue. I have trouble with large F2b ships, because of arm muscle weakness. The fact that the line tension, of a 40 VF powered machine, is a little less than large, is of great interest! It sounds as though this is an attractive proposition, even though it probably means that I would have to fly in low wind conditions. I assume that the line tension must be related to power output, or is there some other factor in play here?
Andrew.
BMFA Number 64862
