Randy , I always value your opinion.
Why do you believe so many guys out there block the boost ports if , as you clearly state , it doesn't improve the 'Stunt Run ' ?
Robin.
Hi Robin
I have done this with many many engines, It has NEVER as I said increase performance..I never said anything about improving a "stunt run" That is "clearly" a opinion, and there are more of those on that subject than we have engines.
Whenever I block a boost port or multi boost ports the POWER and Performance always goes down. Then you "have" to add a Bigger venturie, or more nitro, or more pitch, in order to get back the lost power, ..note... many people think more speed is more power, ..many people think being able to run a bigger prop that does not run away because it is "out" of power is more power.
I have also done HP and Torque test on all of these, both HP and torque went down when the port was deleted or blocked, with all else being equal..same venturie, prop, fuel, etc.
You have some people that enjoy talking about retimed FPs being weak, I did 100s of them, and my guys could then run 12 inch props in a solid 4/2, They were not weaker, they were slightly stronger in a 4 cycle, and ssome of the 2 cycle power was killed off by the mild retime/reangle, I think this is somewhat similar to what people see when blocking boost ports on that same engine. You can also do somewhat the same by decompressing the engine to kill off 2 cycle power and this allows you to run the motor harder without the extra 2 cycle "runaway power" that was the biggest complaint of that engine.
Then you had another engine builder that setup his with blocked ports and would run the motors with bigger props in a 2 cycle..so again that solved the 2 cycle runaway problem, Still others would run the same blocked motors witth a lower compression head in a 4/2 with more powerful fuel, These worked but did not have more power or performance, I have to get back to work, I will write more later
