  • June 19, 2025, 06:44:24 PM
Author Topic: Venturi swap  (Read 1581 times)
Offline John Watson
Venturi swap
« on: October 22, 2017, 09:58:51 AM »
I have an OS FP 40 that I would like to put on a C/L plane. Rather than lock the throttle open is there a venturi that would fit to replace the RC throttle?
Re: Venturi swap
« Reply #1 on: October 22, 2017, 10:23:56 AM »
Jim Lee at Lee's Machine Shop has these in stock always.
Offline Fredvon4
  • Central Texas
Re: Venturi swap
« Reply #2 on: October 22, 2017, 12:55:37 PM »
John.... there a several combinations of Venture and NVA to decide on
Lee machine
 Randy Smith
Tower (OS parts)
Shuttrman E-bay
You might consider perusing the Engine set up part of the forums and write down the most used diameter and NVS vs the plane and props and fuels
There s a lot of good info for OS FP 40 to be found way back in the early 2000 up to now
My best advice to save the research time is to just call Lee Machine or Randy...each has a lot of experience on what works best
Fred von Gortler IV
Offline Rick Bollinger
  • AMA 931589
Re: Venturi swap
« Reply #3 on: October 22, 2017, 01:20:07 PM »
Hi John
Go to the vendors section here on the forum and call either Jim Lee or Randy Smith. There contact info should be there. Tell them the plane you are putting this on they will help and get the right stuff right out to you. And welcome to the forum.
Rick
Rick Bollinger
AMA 931589
Online James Lee
Re: Venturi swap
« Reply #4 on: October 22, 2017, 02:22:08 PM »
We are on vacation right now...   Just did the Baton Rouge contest , then some time on the beach before the Tampa Bay contest.
I have venturi,s and nva in stock for the 40FP but it will be a bit before I can help...
Jim
Online Geoff Goodworth
Re: Venturi swap
« Reply #5 on: November 06, 2017, 04:24:31 AM »
I know I'm a bit late to this discussion but try this.
Read the attached and think about the standard OS parts from Tower.
Offline George Albo
Re: Venturi swap
« Reply #6 on: November 06, 2017, 06:58:43 AM »
Thanks for the DOC.  That was a good read.
