  • July 17, 2025, 10:23:31 PM
Author Topic: Venturi  (Read 991 times)
Dwayne
Venturi
« on: November 05, 2019, 11:18:33 AM »
I made this venturi by drilling a piece of aluminum and flaring the top, I'm sure it's been debated here but will a straight through venturi work for stunt?
Offline Manuel Cortes
Re: Venturi
« Reply #1 on: November 05, 2019, 11:36:04 AM »
Hi all.
Yes, it will work perfectly IMHO.
Even not theoretically optimum, the spraybar reduces the venturi area in your configuration, increasing the gases speed, so creating the suction needed.
My Stalker-Modusa SE plain bearing engines (35.42.46) all perform straight "venturis" and they run like a dream.
Nice Merco, BTW. I had success with 7 - 7,5 mm dia venturis in the 35s.
Kind regards from Spain.
Re: Venturi
« Reply #2 on: November 05, 2019, 12:47:32 PM »
   Almost certainly. The classic venturi shape from a textbook (which Randy calls a "true" venturi) is not required to function, particularly in stunt, where flow loss from inefficient shapes is essentially unimportant, and reliable atomization and consistent flow is critical.
   You might get slightly less power for a given amount of fuel draw, but that probably doesn't matter, as long as we are running them far below peak anyway.
Dwayne
Re: Venturi
« Reply #3 on: November 05, 2019, 03:02:48 PM »
Thank you, it's slated for a Thunderbird MK1 that was just given to me.
