  • June 20, 2025, 10:59:51 AM
Author Topic: Can we make a list?  (Read 1519 times)
Can we make a list?
« on: January 24, 2012, 02:08:05 PM »
When I am on places like ebay and RCU looking for engines I have a hard time figuring out if something will make a good C/L engine.
Most of us know about Fox's and McCoy RH and K&B GH. Of course you have the Ro-Jets and PA and the like that are labeled a C/L engines. And we know that 4 strokers are being used but unless you know what you are doing, not real easy to setup.
I talking about 2 cycle RC engines that you can pull the carb off slap on a venturi and go fly. I don't know my ABC's when it comes to engines. So I thought if we could compile a list here that would be a nice to have.
I did hear that way back in the day that OS had a 40 size engine that was real good. FSR?
Anyway if you guys will post'm, I will compile a list.
Thanks! H^^
Re: Can we make a list?
« Reply #1 on: January 24, 2012, 02:26:00 PM »
OS .35 FP
OS .40 FP ( two versions, early better than later)
OS LA .46 ( plug and play, great for classic airplanes and anything up to 620 sq inches or 55ounces)
OS .40 VF on pipe
OS .46 VF on pipe
« Reply #2 on: January 24, 2012, 02:47:22 PM »
For smaller planes, OS LA 25 and FP 20.  There's a specific muffler you want to use with the FP 20 (Google "brett buck tuneup").  There's an FP 25, but what little I've heard about it is negative.
Offline Chris Wilson
« Reply #3 on: January 24, 2012, 03:26:22 PM »
Any of the modern Merco's seem good -
Rustler Merco 40
R&B 51
Rustler Merco 61
Or the mighty R&B 75
These are task specific 'stunt' engines and are about as 'plug and play' as one could wish for.
Second hand, a good condition red/orange head Merco 35 is good also.
MAAA AUS 73427
Offline kenneth cook
« Reply #4 on: January 24, 2012, 07:01:49 PM »
          If weight isn't of concern, the Magnum XL series makes a good runner in the .25 size. This is a ball bearing .25 with plenty of power. Ken
« Reply #5 on: January 24, 2012, 07:29:57 PM »
OS .35 FP
OS .40 VF on pipe
OS .46 VF on pipe
 OS LA 25
FP 20
FP 25
Rustler Merco 40
R&B 51
Rustler Merco 61
R&B 75
Merco 35
Magnum XL .25 (Might be a little heavy)
What's next?
Offline Brian Hampton
« Reply #6 on: January 24, 2012, 07:38:27 PM »
Enya 45 model 6001, two versions, the first with twin rings then the second with a single ring. The later model 6002 was not as good for stunt mainly from timing changes to suit power mad RC guys :).
« Reply #7 on: January 24, 2012, 09:21:56 PM »
Now your done it with your reversion to past mate, I am just waiting for the likes of G21/46's to come along etc, etc.
May as well chuck in the MVVS 51, almost impossible to obtain but has one of the best runs that I have ever seen.
MAAA AUS 73427
Offline Robin_Holden
« Reply #8 on: January 25, 2012, 01:52:59 AM »
Hi all from France .
Don't forget:
The Magnum 36  [ square head ]. ASP & SC 36 same but just different brand name.
Thunder Tiger 36.
Enya 40 , 30 , 25. They're all available in c/l form as well from Randy .
Thunder Tiger GP 42.
Just my two [ euro ! ] cents worth fellas ,
Robin.
Offline DanielGelinas
« Reply #9 on: January 25, 2012, 11:11:13 AM »
Brodak .25 and .40.
Offline Jim Thomerson
« Reply #10 on: January 25, 2012, 01:04:40 PM »
I like the Tower 40 and the K&B 4011.
Offline Lyle Spiegel
« Reply #11 on: January 25, 2012, 04:38:45 PM »
Brodak 40 meets my needs- be sure to break it in and drill out a few extra holes in the rear of OEM muffler. Powermaster 10-22 GMA with a sonictronic R/C idel bar plug ot similar.
Lyle Spiegel AMA 19775
« Reply #12 on: January 25, 2012, 06:25:08 PM »
McCoy 40 Red Head. Super nice stunt run with a traditional 2-4 break. Mostly runs in a 4. Likes a big prop load and 5% nitro fuel.
