Unverified, but I've been told that Eric Clutton no longer sells diesel fuel.
In any case, kerosene (or a scented "lamp oil" if you prefer), castor oil and ether are the components.
K-1 kero is available from many sources, including sevice stations.
Klotz castor oil is available from most hobby shops selling glow fuel and many motorcycle shops (for 2-stroke cycle engines); in a pinch, in 2-6 oz bottles at 'most any pharmacy.
Ether can be a bit problematic - John Deere Starting fluid is the best OTC source, containing the highest % ether, but any ether-based starting fluid should do. Punch a hole at the base of the can, pour into a dark glass container with a
good sealing lid.
Ratios aren't super critical - in your (modern) engine 25% oil, 30-33% ether, balance kero should do just fine.
1-2% amyl nitrate/nitrite or other compounds are commonly added as oxidizers - perhaps worthwhile but very difficult to get and certainly not necessary.
Diesels can be a bit tricky to start initially, but once the needle/compression settings are found they're usually more easily started than glow engines - and no igniter needed.
And once you've learned on this one, any other should be a piece of cake for you.
best of luck with it,
Terry
