  • July 11, 2025, 08:10:22 PM
Author Topic: Ultrasonic cleaner...  (Read 1109 times)
Offline John Castle
  • The Bent Pin
« on: December 14, 2009, 06:45:30 PM »
Not that I would ever do such a thing.. :-[.. but have any of you used your wife's ultrasonic jewelry cleaner to clean engine parts? Do you think that it might remove anodizing?
John Castle
McMinnville, Oregon
AMA# 589650
Online RandySmith
Re: Ultrasonic cleaner...
« Reply #1 on: December 14, 2009, 07:03:54 PM »
Hi John
An ultra sonic cleaner does not do well cleaning a used motor, you will be better off  with a dip carb cleaner, or hot crock pot with AntiFreeze
Removing the anodizing would depend on which chemical you clean it with
« Last Edit: December 14, 2009, 10:00:57 PM by RandySmith »
Offline Rob Killick
« Reply #2 on: December 14, 2009, 09:35:46 PM »
Hi ,
I use an U/S cleaner that heats to 175 degrees F and it does a very good job on "gunky" engines and components , but I have never tried it on an anodized motor , or parts .
Rob K.
Rob Killick , MAAC 33300
Offline tom hampshire
« Reply #3 on: December 15, 2009, 06:26:30 AM »
Heads up....   My ultrasonic cleaner can quickly wreck a ball bearing by setting up a sympathetic vibration so the balls dent the races.  No need to repeat the experiment, so please don't.  Tom H.
Online RandySmith
« Reply #4 on: December 15, 2009, 07:43:40 AM »
The ball bearings , venturie, o Rings, paper gaskets ,etc. should always be removed before you clean the motor.
Offline Dick Pacini
« Reply #5 on: December 15, 2009, 10:02:09 AM »
That is called Brinelling.
AMA 62221
« Reply #6 on: December 15, 2009, 06:42:24 PM »
The crock pot and anti freeze will remove the blue on the OS LA engines.  I did that to a .40 that was inconsistant until I removed lthe coloring, what ever it is.  As stated don't use ultra sonic cleaner  to clean ball bearings.
