  • June 19, 2025, 11:47:33 AM
Author Topic: O.S mufflers for the old .40S engine??  (Read 3723 times)
Offline frank mccune
« on: July 09, 2015, 12:30:28 PM »
    Hello All:
    I am looking for mufflers to be used on the old O.S..40S engines.  I think that they were a model 704 from O.S.
    Anybody have mufflers for sale that will fit these old O.S. engines?
        Tia,
        Frank McCune
Offline Target
  • C/L Addict
Re: O.S mufflers for the old .40S engine??
« Reply #1 on: July 09, 2015, 02:34:04 PM »
Chris
AMA 5956
« Reply #2 on: July 09, 2015, 06:54:55 PM »
Is this the baffled piston ball bearing "H.40" series? There were S, P and R/C versions, IIRC. There was also an official OS .40FP-S, hence my confusion. If it's the .40FP-S, anything that fits a .35FP, .40FP, .40LA or .46LA will work. Otherwise, I'd talk to Randy Smith after the NATS, and see what he can suggest. I really like his CNC tube muffler...but I drill and tap them for pressure, usually.   H^^ Steve
« Reply #3 on: July 09, 2015, 08:13:44 PM »
I think you mean the ' Jetstream ' ,
same fit as 30 , 35 etc , Some cases are lugged & tappeed for these , later ( mid 70s ? ) arnt .
cording to this the 703 is the 35 / 40 job . ( these are the later type )
could find you a few of them , but we're ' across the water ' .
pictures are filched . Youd need to CLEAN any Ive Got ! .  ;D
Online Trostle
« Reply #4 on: July 09, 2015, 08:39:42 PM »
I think the Jetstream muffler was primarily for the OS 35S and the OS 30S.  Which were nice engines before OS came out with the H model series and then the FP series.  The Jetstream bolted inside the exhaust stack.  It is light and is an effective muffler.
I really do not know what the OS 40S is.
« Reply #5 on: July 10, 2015, 04:57:51 AM »
Frank,
I have some, I'll take a look.
Footprint has to match up.
Offline Bill Johnson
« Reply #6 on: July 10, 2015, 06:12:50 AM »
Frank, if you register on the RC Groups.com forum and post a WTB there, you'll probably get several offers. A 703 muffler with strap just sold for $8. I picked one up there for $10 a month ago. That form is a great place to find old engines and parts.
Another option is buy just the strap, and it can be the OS or the Enya. I prefer the Enya because it uses the existing holes on a muffler while the OS requires a tapped hole on the side. Then buy a tongue muffler. To get the right tongue muffler, get the dimensions of the exhaust port width and you can figure out which Brodak muffler will work. I have the hole spacing on all their mufflers.
Best Regards,
AMA 350715
Offline Robert Zambelli
« Reply #7 on: July 11, 2015, 08:08:20 AM »
Frank: If you post the exact center-to-center distance, I can tell you if there is a Brodak muffler that will fit.
Offline YakNine
« Reply #8 on: November 25, 2015, 07:36:49 PM »
Mac's makes a strap on muffler that fits perfect , I have an Rsm tongue on another one that is drilled through the case for bolts.T.J.
AMA 85135        GSCB
