  • June 21, 2025, 04:28:38 AM
Author Topic: Sr .29-.35 parts swap?  (Read 1605 times)
Offline frank mccune
« on: July 15, 2015, 11:44:22 AM »
     Hi All:
     Will a new piston , cylinder and crankshaft (.29) fit into a G21/35 to make a G21/.29? I have a tired G1/35 and all of the above parts.  Can I make a "new" G21/.29 with these parts?
        Tia,
        Frank
Offline bob whitney
Re: Sr .29-.35 parts swap?
« Reply #1 on: July 15, 2015, 12:02:52 PM »
why do u want to put the 29 stuff in a 35. i think some of th 29 abc sleeves will fit in some of the 35 cases but u will also need the 29 head
rad racer
« Reply #2 on: July 15, 2015, 03:30:04 PM »
     Hi Bob:
     Good to hear from you. I have a supply of odd and ends of engine parts and I like to play with engines.
        Be well,
        Frank
« Reply #3 on: July 21, 2015, 10:49:45 PM »
I'm curious to find out. I have some G.21 .35 stuff and a G.21 .29rv that could use a new piston/cylinder. If I could come up with a new P&L, I'd made a takeoff dolly and fly it (B Speed from circa 1967).
