Engine basics => Engine set up tips => Topic started by: frank mccune on July 15, 2015, 11:44:22 AM
Hi All:
Will a new piston , cylinder and crankshaft (.29) fit into a G21/35 to make a G21/.29? I have a tired G1/35 and all of the above parts. Can I make a "new" G21/.29 with these parts?
Tia,
Frank
why do u want to put the 29 stuff in a 35. i think some of th 29 abc sleeves will fit in some of the 35 cases but u will also need the 29 head
Hi Bob:
Good to hear from you. I have a supply of odd and ends of engine parts and I like to play with engines.
Be well,
Frank
I'm curious to find out. I have some G.21 .35 stuff and a G.21 .29rv that could use a new piston/cylinder. If I could come up with a new P&L, I'd made a takeoff dolly and fly it (B Speed from circa 1967).
