  • June 19, 2025, 05:27:16 PM
Author Topic: LA 46 crankshaft different  (Read 1599 times)
« on: April 13, 2016, 08:53:01 PM »
I got some metal Backplates to swap out on two of my LA 46s.
I noticed the crankshafts were different. I pulled them out and weighed them.
One has a counter weight that looks to be cast the other smooth and machined.
The smooth one is 3 grams heavier.
I did a search and did not find much but found one thread that said something about replacing a LA crank
with a FP crank made a difference and some people added weight to the counter weight.
Thoughts?
« Last Edit: April 14, 2016, 01:43:21 PM by Paul Taylor »
Offline Jim Oliver
Re: LA 46 crankshaft different
« Reply #1 on: April 14, 2016, 06:05:40 AM »
Paul,
Just wondering if you have any idea of the time of manufacture of the two engines in question?
Of the several LA 46s I have (blue and silver), I think all have the machined shaft.
Jim
Jim Oliver
AMA 18475
Offline Akihiro Danjo
« Reply #2 on: April 14, 2016, 10:48:50 AM »
Left one is a very first lot.
Aki
« Reply #3 on: April 14, 2016, 01:24:10 PM »
It appears to be timed a skosh differently too.
« Reply #4 on: April 14, 2016, 01:35:12 PM »
The early ones had the cast cranks, the later have the heavier ones, they are all still supposed to be for the 35 , 40 FP and  40 46 LA
« Reply #5 on: April 14, 2016, 01:48:22 PM »
Thanks guys.
