Engine basics => Engine set up tips => Topic started by: Paul Taylor on April 13, 2016, 08:53:01 PM
I got some metal Backplates to swap out on two of my LA 46s.
I noticed the crankshafts were different. I pulled them out and weighed them.
One has a counter weight that looks to be cast the other smooth and machined.
The smooth one is 3 grams heavier.
I did a search and did not find much but found one thread that said something about replacing a LA crank
with a FP crank made a difference and some people added weight to the counter weight.
(http://uploads.tapatalk-cdn.com/20160414/c8fa890ffc58e4a7b88f8d0067f5b168.jpg)
Thoughts?
Paul,
Just wondering if you have any idea of the time of manufacture of the two engines in question?
Of the several LA 46s I have (blue and silver), I think all have the machined shaft.
Jim
Left one is a very first lot.
Aki
It appears to be timed a skosh differently too.
The early ones had the cast cranks, the later have the heavier ones, they are all still supposed to be for the 35 , 40 FP and 40 46 LA
Thanks guys.
