  • June 26, 2025, 08:07:50 PM
Author Topic: Supertigre 46 with no ring.  (Read 1400 times)
Offline Curtis Shipp
  • AMA 753063 / Advanced Stunt Flyer Finally
« on: December 10, 2011, 04:42:16 PM »
While going through my tigre 46's I found 1 engine that has no ring. Anybody know anything about this engine?
Life is to short to be sour.
Re: Supertigre 46 with no ring.
« Reply #1 on: December 10, 2011, 06:30:07 PM »
Is the sleeve brass?
Offline Balsa Butcher
  • High Desert Flier
« Reply #2 on: December 10, 2011, 06:55:48 PM »
Could it have been rebuilt with one of the Bristunt ABC P&L sets?  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #3 on: December 10, 2011, 07:27:59 PM »
Sleeve appears to be steel or cast iron. Piston looks chrome plated or aluminum. It is an older no lug case and the sleeve has no bridging for a ring. I may take it apart and get a better read on the parts. It is brand new or a very good rebuild but no name other then supertigre.
My bad it is a 35. I had it in my box of 46's and did not check the size. Still what is it. Is it any good for stunt. Like on a smoothie. Is it a combat engine. It looks just like a 46 except for no gap under the cylinder head.
« Last Edit: December 10, 2011, 07:54:02 PM by Curtis Shipp »
« Reply #4 on: December 10, 2011, 09:43:16 PM »
If it is a 35 it would be a combat motor if there is no baffle on the piston, if there is a baffle it is a stunt motor. That is the G-21 35, there is also a plain bearing 35 that also has both flat top and baffled piston versions
Does it have  G-21 on it  or does it have a  "C"  on it?
« Reply #5 on: December 11, 2011, 02:01:19 PM »
The engine has a flat top piston, stunt venturi and g21-35. It has 1 exhaust port/no bridge and 2 intake ports/with bridge. It has no C anywhere but came with a very large short venturi.
« Last Edit: December 11, 2011, 07:27:17 PM by Curtis Shipp »
« Reply #6 on: December 11, 2011, 09:48:47 PM »
It is a G21 35 combat motor
« Reply #7 on: December 12, 2011, 12:20:44 AM »
....and it goes like hell!
