  • June 19, 2025, 04:23:21 AM
Author Topic: OS 35 S Does it have a head gasket and if so where can I purchase one?  (Read 1935 times)
Offline Walter Hicks
I have just purchased a clean and not worn OS 35 S  from EBAY. Upon inspection I cannot find that it has a head gasket unless it is stuck well to the head. Do these have head gaskets and if so where can i purchase one? This is the newer one not black fin model.Thanks
Hi Walter
Yes they do have and  need  a  head gasket, I have lots of those engines and parts, gasket sets are slim pickins  but  I think I can find you one, I will look when I get in the shop and let you know
Theyre Al Ominum Gaskets . So Its pobably THERE , & Hiding .
Generally you need to get the scalple tip under it , to prise free from the head.
Cant remember if its like the 40 and hiden up inside a relief the diameter of the top of the liner .
pretty Cunning .  ???
Yeah, I was sure my fp40 didn't have one, but sure enough it was there, just stuck tight in its groove looking just like the bare aluminum head.
Rusty
Thank you for all the replies.
Offline Brian Gardner
I have some head shims left from the last production run of ABC sets for the 35. Let me know if you still need.
Hi Walter
I did  pull the  parts box out,  I have gasket sets  for  the  35  and  for the 30
Hi Randy, How do I pay you I have Pay Pal. Thanks
PM sent  or  call  678 407 9376  or  email , its  below
Randy     Randyaero@msn.com
« Last Edit: April 20, 2018, 12:52:32 AM by RandySmith »
