  • July 17, 2025, 05:30:43 PM
Author Topic: Enya .45 PL Pro mods ?  (Read 1035 times)
Offline Rob Killick
« on: January 04, 2008, 10:27:14 PM »
Hi ,
I recently purchased an Enya .45 S PL Pro .
The engine has four muffler mount holes (the wide holes are through holes and the narrow hole spacing are blind threaded holes) .
My question is this ...
Can I mill off the outside through hole lugs , as to save a little weight ? I can always fit a tongue muffler to the blind holes . It looks like I have plenty of "meat" to spare .
Might this damage the engine ?
I have some very competent machinist at the machine shop I work at that can do the job for me , so I'm not really worried about any mess-ups .
Any recommendations ?
Thanks in advance  y1
Rob Killick , MAAC 33300
Online RandySmith
Re: Enya .45 PL Pro mods ?
« Reply #1 on: January 04, 2008, 10:40:39 PM »
Hi ,
Hi Rob
I would not do  that, you will loose  almost  no weight at all and  will take a chance of chips in the motor or damage taking it apart  plus you will loose the ability  to use a Bolt on tube muffler.  It just is not worth the  effort
Offline Rob Killick
« Reply #2 on: January 05, 2008, 08:18:23 AM »
That's what I wanted to hear .
Rob K.
