Engine basics => Engine set up tips => Topic started by: Rob Killick on January 04, 2008, 10:27:14 PM
Hi ,
I recently purchased an Enya .45 S PL Pro .
The engine has four muffler mount holes (the wide holes are through holes and the narrow hole spacing are blind threaded holes) .
My question is this ...
Can I mill off the outside through hole lugs , as to save a little weight ? I can always fit a tongue muffler to the blind holes . It looks like I have plenty of "meat" to spare .
Might this damage the engine ?
I have some very competent machinist at the machine shop I work at that can do the job for me , so I'm not really worried about any mess-ups .
Any recommendations ?
Thanks in advance y1
Hi ,
Hi Rob
I would not do that, you will loose almost no weight at all and will take a chance of chips in the motor or damage taking it apart plus you will loose the ability to use a Bolt on tube muffler. It just is not worth the effort
That's what I wanted to hear .
Rob K.
