  • July 09, 2025, 10:19:27 PM
Author Topic: Stock ST 51 advice.....  (Read 5253 times)
Offline Rick Henry
« on: July 19, 2011, 07:59:53 AM »
I'm finishing up a new plane and my goal is to have it ready to go and have a little time to fly and practice with it before the FCM contest.  The airplane is set up around a ST 51 and I have a brand new made in Italy C/L version "stock" that has never been fired up.  Most guys seem to change the venturi and needle location or have the engine re-worked but I want to run it as is if possible. I have been told that the stock version works well in a profile but may not work out so well in a full fuse model.  Is this true?  I plan to use a plastic clunk tank and I can center the draw tube on the needle but what else should I know about this engine Any advice?
Rick Henry
Offline Keith Renecle
Re: Stock ST 51 advice.....
« Reply #1 on: July 19, 2011, 09:24:10 AM »
The ST 51 is certainly not up to the legendary ST60, but some folks seem to get them to work without too many mods. The best one that I've witnessed was that of Henk de Jong from the Netherlands. If I'm not mistaken he just added head shims to lower the compression. From my own experience, this was a must otherwise the thing just runs away after a few good loops. My last model with this engine in it used to run away after the triangles.
One guy that is a whizz with modifiying ST's is Tom Lay, so I would suggest contacting him if you want to go this route. One more thing, please don't use the stock muffler..........it weighs too much and is HUGE! I was lucky to get one of those German Kuentz (not sure about the spelling) mufflers, but there must be a few others around the USA that you can get hold of. Big Art Adamisin used to make them a while back. Good plugs that worked for me were the Thunderbolt 4-stroke or the Enya no.3. The prop that worked the best was a 12 x 5 wide blade wood prop. I used mainly Zinger 13 x 5 that I cut down to 12" with rounded and thinned tips.
Venturi size is important as well but if I remember correctly, the stock C/L venturi worked fine. I gave up on the ST 51 when I went over to the MVVS stunt .49 which was a much better deal all around. Unfortunately the factory stopped making them a few years ago when electric motors started taking over. When I could not get a good 2/4 break, my final version of the 49 was a diesel head, and this worked very well for me for many years. I could not diesel the ST 51 because it is a ringed engine. I suppose that you can but cold starting is a problem. Good luck with the new stunter!
Keith R
Keith R
Offline Brian Hampton
« Reply #2 on: July 19, 2011, 10:07:24 AM »
I have the Italian G51 and ran it box stock standard in a (large) full fus model, zero nitro all castor fuel and a Zinger 12x5 prop. With 20% oil the engine overheated because it's exceptionally economical but 25% oil cured everything. The only complaint I had with it is that the ground setting was quite different to in flight so needed several trial flights to get it correct. Easy one flick starts too.
« Reply #3 on: July 19, 2011, 10:38:14 AM »
   Do a search on the site here and you should find quite a bit on the ST.51. I have used this engine almost exclusively since 1994 and have two stock engines that have an untold number of flights on them and still on the original ring. The basis of my set up is the following: One or two head shims as needed, tube type muffler (like a Scott Dinger, Big Art, or Randy Smith muffler) Glow Devil R/C Long plug ( or similar hot plug) APC 12.25 by 3.75 prop, at least a 6 ounce tank with uniflow on muffler pressure and SIG Champion 10% fuel that has at least a couple more ounces of castor oil added. I usually mix regular SIG Champion 10% and SIG 10% ALL Castor 50/50 and this leaves enough Klotz synthetic in the fuel to help keep things clean. The .51 is a ringed engine and the use of castor oil is important for lubrication and to help carry heat out of the engine. It makes the plane all gooey and messy, but paper towels are cheap and engines are expensive. The APC 12.25 by 3.75 is the best prop I've found yet. Take off RPM will be between 9500 and 10,500 RPM depending on your model weight and such. The APC is the first prop that I was able to really experience the flat pitch/high RPM effect  on holding a model back from winding up in the wind and gets the engine up into the heart of it's power curve. If you use too much pitch you can get it to run away. I have used the Master Airscrew 12 by 6 three blade cut down to 11 inches ( it actually pitches out at 4 inches of pitch on my Prather Pitch Guage ) and it works well but it can run away if RPM is too high. I plan on experimenting with pitching one down to 3.5 inches as time permits. I have a SIG Magnum that I let the weight of it get away from me (72 ounces) and the ST.51 flew it as well as could be expected. Won a contest or two with this set up in this airplane. I think the .51 has about as much power as the old ST.60 but it is a different kind of power, not as much torque from the .51 as it won't turn a 13 inch prop like the .60 will. The .51 gets it power from RPM in the 9 to 10,000 range while the .60 likes it best down in the 7500 to 8500 RPM range. I've been flying both engines in comparison for the last several years to be able to make that conclusion. This set up I mention above has been very repeatable in several models and is always where I start out with. I can also HIGHLY recommend a Tom Lay reworked engine. I have a couple of those in models also and they are very good deal. Tom checks out the cylinder to make sure it's round, changes venturi and needle location, adds a hardened Bowman ring and I'm sure a few other odds and ends. All of this adds up to an engine that will live a LONG time if cared for properly. There was some concern when Super Tigre moved operations to China, but I have not heard of any problems with the production engines since the move. If you order rings from Frank Bowman, he'll ask you which version you have only if you ask him to gap the ring for you, as the China version has a bore that is only a fraction of a gnats hair larger than the Italian version. if I remember correctly. The only issue I have ever had with the ST.51 is the prop drive washer, which is cast aluminum and can crack if you over tighten the prop, but I have only done that once and they may have fixed that problem. All in all, either stock or rework, the ST.51 is a pretty good buy for a stunt engine and I think you'll like it.
   Good luck and have fun,
« Reply #4 on: July 19, 2011, 10:53:00 AM »
   Hi Brian;
     You bring up an interesting point that I don't think a lot of people realize. When you have the model restrained on the ground and set the needle, you have the engine loaded a bit higher than when in flight, and no centrifugal force at work on the tank. When you release the model, the engine unloads a bit as it gains momentum, and as the model gains speed over the first lap or two, centrifugal force goes to work and makes the engine run a bit richer, even with muffler pressure. And this isn't just on the ST.51, it happens on all engines, just is easier to hear on certain engines. This is an indication that you have a good, tight fuel system with no leaks of any kind. That is why I use a tach when I  set my needles. I'm not worried about what the actual RPM is, just want a visual reference so I can get the needle set right every time. With today's engines, 200 to 300 RPM can make a big difference, and with my hearing I can't tell the difference most of the time. Temperature difference from a cool morning to a hot afternoon makes a big difference also on fuel consumption and I need the tach to get the RPM right. I never tried zero nitro, though, but I don't think nitro content will affect the presure changes of a restrained model and a model in flight.
Offline Marek Kozera
« Reply #5 on: July 19, 2011, 10:59:56 AM »
I gave up on ST 51 in the full fuse model because it was difficult to start. I had to use an electric starter which was not the most practical option.
I have installed the same engine in a profile – no problem starting.
Marek
Offline Rick Henry
« Reply #6 on: July 19, 2011, 11:14:31 AM »
Thanks guys.  I should have mentioned I have one of Randys tube mufflers for the engine. Sounds like a similar setup as my LA 46 with the APC 12.25 X 3.75 prop and high RPM.  I have an older Big Jim ST 60 but I really wanted to try the 51 in this new plane.  Its a modified Time Machine but has built up flaps and a built up tail.  I changed the fuse to look like a crop duster but all the moments and areas are Time Machine.  I am shooting for 54 oz finished ready to fly weight with a Monokote finish and I think Im right on target but we will see.
Rick Henry
« Reply #7 on: July 20, 2011, 02:11:21 AM »
They like to rev , and will switch with load .Not a ot of nitro needed , if any .
Id giv it a litre on the bench , another in the air , then give it grief shamelessly .
They sound as if the top will blow off on a 10 x 4 three blade , so fit extra gaskets.
nough grunt to haul anything through any wind .70 Oz givs them some work to do
and gets all the pressures / switch thing happening .
12 x 6 is a good run in prop for a profile , steady speed .
needs less prop for good yachting weather . :!
« Last Edit: July 20, 2011, 05:25:21 AM by Matt Spencer »
Offline John Sunderland
« Reply #8 on: July 20, 2011, 02:44:10 AM »
 D>K Joe Reinhard is running a newer chinese (small letters) ST51 but... he has had some of the best running Italian versions I have ever witnessed or flown. Tigre 60s too. Joe knows how to "prop" an airplane and has had great success just innovating over the years, not to mention fantastic models of his own design.
Joe fashioned a strong 4 stroker Tigre 51 20 years ago.  Yep, head shims, a few, stack venturi, honed sleeve and a new ring, hot plug, without an idle bar. Hemi heads and a 57 oz. bird.
His China made offering has powered a much bigger airplane of classic 60's European proportions that weighs even less which just blows my mind, but it flies where you point it.
Send me a pm and I will give you Joe's number. You fly in similar conditions to us and less than 200 miles apart.
« Last Edit: July 21, 2011, 11:02:12 PM by John Sunderland »
Offline Chucky
« Reply #9 on: July 20, 2011, 05:55:44 AM »
I've been flying the Chinese ST's in R/C and C/L planes for about 7 years now.  I fly two of the G-51 C/L motors box stock -- one inverted in a Legacy, and one on its side on a profile.  Both are 1 or 2 flip starters that purr along nicely with a light 4x2 break in stunts spinning an APC 12.25x3.75 burning Wildcat Premium Extra 10% nitro amended to 22% lube.  I'm using Randy Smith tongue mufflers on both with the holes drilled out the next size larger to reduce back pressure a bit.  I also fly a couple of the ST G-34 C/L motors, with a few minor mods to reduce head bulk and setup a remote needle valve, in combat planes.  It's a great S/L combat engine for the price and delivers a nice steady run on 10% nitro fuel with 20% oil, APC 9x4, and bladder.  Green, I've found the ST ringed engines to be no fun whatsoever with low compression and erratic performance so make sure yours is thoroughly broken in before making changes.  I was given two new G-51's (one R/C, one C/L) by frustrated modelers who couldn't get them to run right.  In both cases, break in solved the problems.  Unless you plan to have the ports re-timed to mimic the behavior of a Fox 35, use a low pitch prop to keep you and your motor happy.
« Last Edit: July 20, 2011, 06:24:26 AM by Chucky »
Chuck Winget
« Reply #10 on: July 20, 2011, 11:51:17 AM »
   Keep in mind also that there IS a difference between the R/C version and the C/L version. The C/L version has a different cylinder liner. Pull the parts sheet out that comes with the engine and check it out.
Offline Chucky
« Reply #11 on: July 20, 2011, 04:53:57 PM »
Agree, the R/C version is different.  I fly mine on an R/C Hangar 9 Twist.  The ones on my C/L planes are C/L motors.
Chuck Winget
Offline Dalton Hammett
« Reply #12 on: July 21, 2011, 09:38:03 AM »
Hello
     I'm no expert but I am running an Italian ST .51 on a 60" profile now and it has been an excellent choice.  Very fast 1 and 2 flip starts and very good runs using high castor as some have said above and an 11/5 prop.   I started out with some bad engine runs but that turned out to be a tank problem rather than engine problem.  I haven't tried one in a bodied plane as yet but may put one in a T-rex at some point to see how it does.   I don't use the big tank muffler on the engine though,  it's just too big looking for me.
Best of luck with it
Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Offline John Lindberg
« Reply #13 on: July 21, 2011, 12:55:01 PM »
I have a Randy Smith ST .51 that runs very well, currently it is in a Nakke, I highly reccommend getting one from Randy, he balances and blueprints the engine, and sets it up properly, and he is easily accessible to answer questions. All for around $159.00, ready to go, cheaper than other modified ST's. Hard to go wrong, there, I believe! :!
« Reply #14 on: July 21, 2011, 02:45:41 PM »
HI Rick,
Wish I could help, but all my ST .51s have been Tom Lay engines.  I have also seen Randy's  engines and they run super, also.  I was given a Tom Dixon Italian .51 and it is just slightly down on the power of the others, but uses less fuel and more pitch.
On the T&L engines I have used props in the 4 1/2 to 5 pitch range and they run at a higher rpm than the ST .60s, (Big Jim, Tom Lay), but still have a tremendous stunt run.  The best prop on my USA-1 was a fl;at back Eather 3 blade set at 4.75 pitch and 11.25 diameter.
Just have never tried to run one stock.......  I agree with Dan Mc that they put out as much, or more HP, but probably not as much torque as a ST .60, hence the smaller props.  My first one did pull a 64 oz. SV 11 with absolutely no problems under any conditions.
BTW: I am finishing a modified Time Machine/Patternmaster .51 using a Steve Buso fuselage drawing.  Power for it will be a Big Jim Hemi ST .60.  I hope to use it in Huntersville for the October Meet.
Big Bear
Offline Andrew Tinsley
« Reply #15 on: July 22, 2011, 06:20:38 AM »
Well, looks as if I am in a minority. I too had an Italian ST51 and it just wouldn't run consistently. I tried all the ususal tricks, that are to be found in the archives and absolutely no joy. It really was a bit of a disaster, several of the top stunt pilots in the UK have not got a good word to say about standard ST 51s, they claim that a rework is mandatory and even then there are much better engines than the ST51. I agree with Keith about the MVVS 49 in both standard and diesel trim.
I replaced the ST51 with an ST 60 and what a difference, a real pussy cat. Mind you, it does vibrate more than a bit.
Andrew.
BMFA Number 64862
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #16 on: July 22, 2011, 08:17:44 AM »
Andrew.
Nope you are not alone, look for my ST 51 posts down in the engine section and you will see I've been fighting a stock 51 for several years. I managed to get through my officials at Brodak's by adding two head shims and running 20% nitro to get the power back. It worked realy well but would be nice to be able to run 10-22.
Offline richardhfcl
  • AMA 82448
« Reply #17 on: July 22, 2011, 08:29:56 AM »
Andrew,
     I have to agree with you:  my experience has been that all Tigre G-51's do not run when box-
stock, right out of the box.  Some do, but most do not.
     Perhaps, this is why we hear from those who, either found one of the few that do run well right
out of the box, or who fly engines which have been modified.
     I love my two G-51's now that they have been reworked and run decently, and I'm just glad that
I had other engines to fly until I got the Tigres back from the rework guys.  Were I too do it over I
think that I would just buy the reworked engine from Randy and be done with it.
     Best regards,
Richard Ferrell
AMA 82448
« Reply #18 on: July 22, 2011, 10:33:05 AM »
I know Tom Lay does wonders with the ST 51.  Mine runs just great in a Legacy.
But how hard can it be to rework them?  You need a Bowman ring.  You need to be able to gap the ring and hone the cylinder.  Maybe replace the bearings with better ones.  Other than that, what is there?
Offline Ward Van Duzer
« Reply #19 on: July 22, 2011, 10:51:26 AM »
Uh...Timing, Balance, Cleaning (interior), heat sinks, fitting, PROPER assembly and torqueing, Venturi shape & size, NVA, and position and...
W.
« Reply #20 on: July 22, 2011, 02:21:49 PM »
Floyd,
I would really like to know "what else is there" I have no doubt that reworked ST 51s are good. It is the stock ST51s that can either be just fine or down right pigs. My particular one was a new Italian one. I ran it in correctly and was rewarded with an engine with excellent compression and one flip starts. Then the trouble began, it would run away at various parts of the schedule, sometimes it behaved. Now I went through the archives and tried every set up that people said was good, including extra castor, no end of props and a whole range of venturi sizes. The basic unpredictable runaway was always there. The only way to stop it was to overprop and strangle the breathing (smaller venturi). That cured the runaway, but power wise it was useless.
  I still have it,never like to get rid of things! So if anyone has any new suggestions to make it behave, I will give it a try. I truly believe that ST made so many production mods on the ST 51 that you don't have one engine, but quite a few different ones. I suspect this is the reason for such a wide variation in how it runs.
Andrew.
BMFA Number 64862
« Reply #21 on: July 22, 2011, 02:48:45 PM »
All the things Ward speaks of above do really figure into how a engine runs, of course.  I have never asked Tom, nor Randy, what they actually do to a ST G.51.
I am sure that balancing and "blueprinting" are in the mix.  I suspect that Tom does some mild retiming which keeps the engine in check while not dropping a ton of power.  So far his examples have shown to be able to pull a large stunter with plenty of authority.  Randy's are the same way!  Again, I feel that horsepower wise, the ST G.51 rates pretty even with a ST .60, but not in the torque range.  It will just not swing as big of a prop as the ST .60.  But the higher rpm run, coupled with less pitch gives the HP to fly a pretty good size stunter.  Let's be realistic, there are those who know how a stunt engine should run and what to do to make them do that.  There are also others who "rework" an engine but the "guts" are gone when finished.  Not a whole lot of people can make the engine run and still have acceptable power.
I will site Lou Crane and Larry Foster who "rework" Fox .35s.  They work to make the fits correct and reduce vibration.  With these mods the engine picks up power with out losing it's run characteristics.  I know there are others who do a wonderful job, but I site these two because of the engine (Fox. 35! the "Ancient of Ancients"!) and the simplicity of what they do to make the engine so much better.
So, are reworked engines worth it?  I would give a resounding "YES", as long as the person doing it has a well established record and his engines are known to work better than stock.  Before the advent of PAs and RoJetts, almost every top level flier had a reworked engine to some degree.  If nothing more than to make the engine more reliable.
Do "ALL" engines need to be reworked to perform as we like?  NO.
Big Bear
Offline Jimmy R. Jacobs
« Reply #22 on: July 22, 2011, 08:45:32 PM »
  Bill , I have a st 50 V that I would not trade for 2 ST G.51s.  This engine has the sweetest 2/4 break and my grandsons would probably kill me if I traded it for two ST G.51s because they've been breaking it in for me on a big, gentle stunt plane and they love the way it sounds and runs when it has the 2/4 break with a tube muffler I built.  I also tuned the engine my way with the stunt tunes I know of.  I have a lathe and a mill in my shop to work on engines and I also weld aluminum.  The G.51s has 2 muffler lugs welded on for a regular tube muffler.  It has about 80 flights on break in now and both grandsons have flown in a lot and they love it.  They have only been flying for 2 1/2 weeks and have burned almost 4 gallons of fuel!  We have had a training and one grandson has built a Twister.  The other one is going to build a Super Clown.  Both boys have a LA 40 OS that I've stunted tuned also and we've had no run aways and a very nice 2/4 break with props from 10-6 to 11-5 and no run aways and a nice 2/4 break with either prop.  BTW did I say no run aways??!  We're flying tomorrow and the grandson who just built the Twister will be flying it for the 2nd time.  He flew it today 5 times.  No crashes, loved the engine run with the LA 40.  The Twister has grandpa's modifications in it and his kit bash.  We'll add pictures later.
-Jimmy Jacobs  (I'm having so much with these grandsons that I feel like an 18 year old!)
« Reply #23 on: July 22, 2011, 11:25:44 PM »
If a G-51 is giveing you GRIEF reciprocate in kind .
Its a detuned 16.000 rpm R/C motor of 1.6 H.P.. %^
Throw a 10 x 6 prop on it on the bench , stand back,
and wind'er up for a few tanks. This should blow the
cobwebs out of it, or put the rod through the side. ~^
Bit like a V-12 Jag , biggest problem is theyre mostly under used.
What do you do if you meet a Tigre on a Dark Night ? ?
Tickle its tummy till it opens its mouth ,
Then reach down its throat and grab it by the tail .
Then give it a good tug and turn it inside out .
Pussy footing around will most likely let it get the better of you .
Fuel correct and everything tight and ship shape , she'll take a
real work-out , and come back for more .
Box stock it should loaf around the scedule on a 12 x 6 ( nylon and a 3 in spinner gives it a bit of flywheel ) in a 2 kilo plane .
Two 11 x 5s lap jointed will get it in the ball park for dragging monsters . It may have less accesable Tourque below 10.000
than a V-60 , but let it of its leash and itll tear up anything in site. So well have none of this pussyfooting , itll get you nowhere .
 :## :X n~
It depends on youre definition of civilised ; Defn ? see Maseratti Ghibli !  Z@@ZZZ D>K H^^
« Reply #24 on: July 23, 2011, 08:22:24 AM »
Matt S. I like your thinking.  I remember back when I was playing with RC a fellow flier was trying to get consistant runs on his new Tigre.  I do not remember the size.  I looked at him one day and asked if he was trying to break it in, it was an ABC engine.  We took off the high pitch prop he was using and went to a lower pitch and smaller diameter.  One flight and he couldn't beleive it was the same engine.  It always started great but would not throttle like it should.  Different prop and let it wind up and it was great.
« Reply #25 on: July 23, 2011, 09:24:31 AM »
I have done the low pitch high rev scenario and still the runs are inconsistent. It just doesn't work like an FP 20. To be perfectly honest I don't care how it runs as long as its repeatable. It is almost as if there is some crap floating around in the NVA. I hasten to add that there isn't, but that is how it runs, just no consistency. Faced with a problem like that, I have just given up.
I really have spent a lot of time on this engine and literally have tried every suggestion in the archives (and that is a lot of options!). I am too old to waste any more time on it. I just want an engine that I can run straight out of the box. The big Mercos and ST 60s are just trouble free until the ring goes. An FP 20 and LA 46 seem to be bullet proof and user friendly and so is the OS 40 VF and Thunder Tiger GP42. With engines around like this, why bother with anything else?
Andrew.
BMFA Number 64862
« Reply #26 on: July 23, 2011, 10:03:35 AM »
    Super Tigre .51's use, of course, a Super Tigre needle valve. One thing I noticed early on was that the fine taper of the needle point can get worn from vibration, kinda fish mouthed or scalloped. I make a point of changing the needle or at least checking it's condition at the first sign or trouble. Also, the locking collet needs to be pretty snug so the needle doesn't move or vibrate like a tuning fork. That affects the run no matter what engine it is.
« Reply #27 on: July 23, 2011, 10:42:24 AM »
Thanks for the tip Don, it wasn't my problem as I have had 3 different types of NVAs in my ST 51 and they all behaved the same.
Andrew.
BMFA Number 64862
Offline MrSteve09
« Reply #28 on: July 25, 2011, 07:24:09 AM »
Hi All,...
I am currently putting a Super Tiger 51 in a Cardinal Evolution.  I am at the point now where I need to install a fuel tank.  How much fuel does this engine need to complete the pattern?  How big of a fuel tank do I need to install?  I've scanned this thread hoping I'd find mention of the fuel tank size, but I either missed it, or couldn't find the information.
Any advice or thoughts would would be welcome.
Thanks!!
Steve T.
« Reply #29 on: July 25, 2011, 10:22:41 AM »
 If it's a stock engine, plan on at least a 5 ounce tank. There are metal units available out there in that size if you can't build one. Six ounce if you have the room. Plastic tanks are fine, and use both with uniflow on muffler pressure. As temperature ranges change, you will find changes in fuel consumption. In the heat of the arly summer at the SIG contest I have had to short tank it down to 3 3/4 ounces to shut down in time. When the temps get below 60 degrees, it gets back closer to 5 ounces. At SIG this year, on the Tom Lay rework I have in my Charmer, I ran out of fuel in the clover with 4 1/4 ounces on board, in the cool air of the morning. I think I was one of the first three. In the warmer air of the afternoon, approximately 15 to 20 degrees warmer, I over ran by 10 seconds on the same amount! It pays to keep some sort of notes or records and I should do that, but I'm a little lazy. Your nitro content will affect fuel consumption also, but if you can put a 5 or 6 ounce tank in it, you should be fine.
    Good luck with the project and have fun,
« Reply #30 on: July 25, 2011, 11:26:22 PM »
Run it on a test stand first at the revs you'll likely fly with using a tank of known capacity and time it. I fitted a tank in my model based on what I'd read that others were using with the G51 (6 ounce) and 13 minutes later...........
The next tank I fitted was a 3 ounce and even then I had to withdraw a little fuel for a 6 minute flight. This was with zero nitro but running a full 4 stroke for the entire flight and the amazing economy was the reason I had to up the oil content to 25% to stop it from overheating.
Offline Robin_Holden
« Reply #31 on: July 26, 2011, 03:27:29 AM »
Hi fellas from a drizzly Charente.
I had all the mentioned problems with my ST51 , the c/l version.
It was properly run-in and had decent fuel but still ran away.I tried everything.
Solution : I sent it to Tom Dixon and it came back in double quick time . It's now my BEST performing stunt engine.
I'm sure Randy or any of the other engineers could wave their magic wand and solve any running issues.
Just my few cents worth ,
Robin.
