Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
August 05, 2025, 03:58:53 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Muffler gasket material?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Muffler gasket material? (Read 1453 times)
Dennis Toth
2020 supporter
Trade Count:
0
Admiral
on:
April 21, 2018, 10:44:19 AM »
Guys,
I need a recommendation on material for a metal muffler to case that will seal yet allow some cushioning so as to not be to tight to distort the case. I have tried some thin aluminum but that needed really cranking down on the bolts. I'd really like something a little softer. Any suggestions?
Best, DennisT
Logged
Chris Fretz
2017
Trade Count:
0
Admiral
Re: Muffler gasket material?
Reply #1 on:
April 21, 2018, 10:53:23 AM »
I sort of asked the same question a wile back, the best answer was to not use a gasket since it will cause the muffler to vibrate lose. Best alternative answers were to file the engine exhaust flange flat and the muffler flange. Or use automotive high heat red gasket sealant.
Chris
Logged
Formerly known as #Liner
AMA 1104207
Advanced
25 supporter
Trade Count:
0
Admiral
Reply #2 on:
April 21, 2018, 10:58:39 AM »
If one really must use a gasket, use sopme gasket material meant for the cylinders of motorcycle engines for base gaskets. It will crush a little bit and seal but may help prevent vibrating loose like soft metal will. Copper sheet will also work but offer the same issue as aluminum. filing the mating surfaces flat and sealing with hi temp sealant is the easiest way.
Type atyou later,
Logged
EAA 1038824
doug campbell
Trade Count:
0
New Pilot
Reply #3 on:
April 22, 2018, 02:37:46 AM »
I have always used liquid silicon gasket. Apply a thin coating, nip up hand tight, and tighten fully once it has set.
Logged
Dennis Toth
2020 supporter
Trade Count:
0
Admiral
Reply #4 on:
April 23, 2018, 10:40:23 AM »
I found some of the old Perfect gasket material (the green paper like stuff) that was still soft and just the right size for covering the exhaust area. I made up the gasket leaving a little extra material on the inside and outside edges (I know this may restrict the flow a little but not much). I was able to then mount the muffler carefully tighting it down with the glow plug removed checking that I didn't tighten one side to much and cause biding (Fox 35 thin case). I also added some blue lock tight on the bolt threads to prevent losening.
Best, DennisT
Logged
Norm Furutani
Trade Count:
0
Commander
Reply #5 on:
April 23, 2018, 01:02:49 PM »
Been using a gasket paper assortment I got from an auto parts store. For mufflers, the thinest, like card stock, works well. I set the muffler flange on the paper, glue it on with CA, then trim with a hobby knife. Nice and neat.
Norm
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
