  • June 20, 2025, 08:26:51 AM
Author Topic: Almost stripped Venturi screw  (Read 2507 times)
Offline James Holford
« on: August 05, 2016, 10:38:50 PM »
Trying to take off the RC carb on my .25FP and one screw is one for dear life.. other came off with ease.
 But this ome screw will not budge and is starting to strip..
 Any idea or solutions to removing this screw without harming the engine?
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Re:
« Reply #1 on: August 05, 2016, 11:15:12 PM »
Nevermind... watched a vid on youtune.. broke out the dremel... turned a stripped.phillips into a flat head and poof it came off :)
Jamie Holford
Lafayette, La
AMA #1126767
Re: Almost stripped Venturi screw
« Reply #2 on: August 06, 2016, 12:41:42 AM »
I would wonder if the heat generated by the Dremel Danger Disc may have had much to do with loosening the screw.  f~ Steve
Re:
« Reply #3 on: August 06, 2016, 08:50:32 AM »
Ahh maybe... had to put some effort in it to break loose.
Jamie Holford
Lafayette, La
AMA #1126767
Offline Phil Krankowski
« Reply #4 on: August 06, 2016, 04:42:34 PM »
I have always needed to heat those up.
Phil
Offline Dane Martin
  • heli pilot BHOR
« Reply #5 on: August 06, 2016, 10:42:25 PM »
Usually,  I grab them with some needle nose vice grips and break them loose first.
Also, Google search JIS screw drivers. They won't strip with JIS because they're not Phillips. It's worth the investment, and a JIS screw driver can be had cheap.
Did you get an os venturi and nva already?
Offline Guy B Jr
« Reply #6 on: August 14, 2016, 11:03:16 PM »
James, please give us a link for the video on u-tube.
Guy Blankinship
Offline Bill Johnson
« Reply #7 on: August 19, 2016, 09:01:49 AM »
Cutting a slot for a standard screwdriver can also be easily done with a swiss file.
I was looking for JIS bits to fit a standard interchangeable bit driver and found these at Motion Pro, a motorcycle repair website:
http://www.motionpro.com/product/08-0576
http://www.motionpro.com/product/08-0577
$3.50 for a 2-pack of JIS bits. No more stripped screws.
Best Regards,
AMA 350715
