  • June 21, 2025, 01:53:31 AM
Author Topic: ST 60 Super Tigre Cylinder HEADS .  (Read 1962 times)
« on: July 07, 2016, 07:29:43 PM »
Picture flogged of Ebay of a Stunt Head , its got a No " 4 " on it , anyone know if its a certain tuner or other .
Any Pictures of Big Jim Heads ? etc .
Below is Stock , with the bigger Bowl one from a Series TWO 60 , dual ring type . Early Head . Others muffler lug case & pdp .
Online RandySmith
Re: ST 60 Super Tigre Cylinder HEADS .
« Reply #1 on: July 07, 2016, 07:55:42 PM »
The left head is a Stock early "Bell head"  the right one is a later model Squish that has had another  plug hole put into it
There were many different stock heads  over the  ST 60 run
« Reply #2 on: July 07, 2016, 11:41:18 PM »
Are the wide squishband heads any good , unmodified .
Is the ' full Hemi ' the Normal stunt set up , or do we get ' creative ' .
Anyone got a machinists drawing , or plasticine and a scalple = Cross Section .for a Big Jim or other renowned ' tooner ' or the Double Star 60 ?
Thanks . ( The ones on the napkin in the 2nd photo are ' on the shelf ' ).
P.S. two of the motors pistons are ' whittled ' on the baffle centre / by plug. Thinking T L might be resposable , as they came from the states
( R C Motors tho. If TL says ' Does Modify them ' I guess they ARE o.k. stock , with gasket / squish clearace set .  :-\
Online RandySmith
« Reply #3 on: July 07, 2016, 11:50:48 PM »
The best  head  is the  K model  squish band head  with the  scalloped  outside, this was the last one made
The Bell  head  is  good for the  older double ring  models
Offline bob whitney
« Reply #4 on: July 08, 2016, 05:52:11 PM »
  any pictures of the K model ready to go
rad racer
