  • July 16, 2025, 07:39:12 PM
Author Topic: Silver Foxx 40 ????  (Read 1427 times)
Offline Jim Nohsey
Silver Foxx 40 ????
« on: December 06, 2014, 05:36:31 AM »
I have one of these in the box and was wondering if any one has used one of them and can tell me anything about it. It looks to be from Lew woolard.
Jim Nohsey
Offline Balsa Butcher
  • High Desert Flier
Re: Silver Foxx 40 ????
« Reply #1 on: December 06, 2014, 01:10:07 PM »
I ran one for a few years. Good motor. Unlike the stock Fox 40 it will run a 4/2/4 break. Use 11/5 or 11/6 prop, 10/22% fuel. More castor is OK, especially until it breaks in completely. Plan on 4.5 ounces for the pattern.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Jim Nohsey
« Reply #2 on: December 07, 2014, 06:00:40 AM »
Ok thanks, I'll have to order me some of them. Don't think I have any 11x5 or 6 prop's.
 Looking at putting this in an brodak nobler that i have frame up.
Jim Nohsey
  • High Desert Flier
« Reply #3 on: December 08, 2014, 04:22:30 PM »
Lack of power will not be problem with that set-up. Mine was in a 54 ounce, 610" wing area Dixon Stylus. It had power to spare. What may be an issue is fuel capacity...try for a 4.5 ounce tank, may be tight on a Nobler, and nose heaviness...try and round up a tongue muffler that will fit. Naturally do some bench running before first flight. FWIW: My favorite engine for a Nobler is an OS 35S. Light, very fuel efficient. Recommend over the Fox 40 if you have one. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Jim Nohsey
« Reply #4 on: December 08, 2014, 05:02:56 PM »
 Thanks Balsa Butcher, I have an tongue for the fox 40.
Jim Nohsey
