  • July 14, 2025, 10:41:01 AM
Author Topic: Silicon joining tube clamps.  (Read 856 times)
Offline Chris Wilson
« on: May 06, 2012, 09:19:24 PM »
Might seem like a silly question but what do fliers use to clamp or tie down their silicon tubing that joins the exhaust stub to the pipe?
Is a cable tie heat proof enough? Or is a spring steel radiator style clamp needed?
Or indeed some other method? Is it even needed?
Thanks.
MAAA AUS 73427
Online RandySmith
Re: Silicon joining tube clamps.
« Reply #1 on: May 07, 2012, 08:16:56 AM »
Thanks.
Hi Chris
MOst use 2 cable ties on each side of the  connection, 2 on the pipe, 2 on the header
« Reply #2 on: May 07, 2012, 04:20:55 PM »
Thanks for getting back to me Randy, cable ties it is then - I was just worried about the heat at the engine end but I guess that the thickness of the silicon is enough to prevent heat transfer.
Cheers.
MAAA AUS 73427
