  • June 13, 2025, 07:43:08 PM
Author Topic: Check the simple stuff  (Read 793 times)
« on: June 26, 2011, 08:25:14 PM »
So, the OS 40VF I've been running as been pretty erratic. Runs OK, slows down, speeds up and seemed anemic sometimes while other times it's fine. I tried all kinds of things: changing pipe length, changing fuel, plugs, etc.
So, I had decided to try the other engine (another 40VF I have) and went to change it out then. I suddenly noticed (how did I miss that?) that the Crap Trap I was using was backwards, crap came into the filter and plugged it. So, I backflushed the filter and put it in correctly. Wonder if it will work now?
Oh well, there's always the back up engine.
Re: Check the simple stuff
« Reply #1 on: June 26, 2011, 11:03:05 PM »
Uh-huh! Last Wednesday at TNA, a certain .25FP was running a little funky. The glowplug was only finger tight. No, I don't own a .25FP.  D>K Steve
« Reply #2 on: June 27, 2011, 11:11:24 AM »
I also noticed a certain AeroTiger .36 that has some run issues (both at TNA and last weekend at the fun fly). Hope a new tank does for that one. Nice plane.
