  • June 18, 2025, 09:40:25 PM
Author Topic: Side Mounted Engine vice upright and inverted  (Read 2390 times)
Offline Hoss Cain
« on: June 23, 2011, 01:50:28 AM »
There are probaly umpteen threads on this question, however maybe somone can give some advice. Many years ago I flew Profiles with side-mounted engines. For regular stunt and scale the engine was always inverted or in some cases upright. That's the way it was!  :D
Now as I am about to get back into CL I am building a Sig Clipped Wing Cub for Scale. It will have a side-mounted engine with head pointed outside. Already set in stone.
My big question is my resurrecting of one of my original stunt designs which had an inverted engine. I am thinking that a side mounted engine will be a better choice. It works fine on the Ringmaster so why not a full blown stunter. Why do I not see many of such?  ???
Horrace Cain
AMA L-93 CD and Leader
Re: Side Mounted Engine vice upright and inverted
« Reply #1 on: June 23, 2011, 09:25:38 AM »
It's not as pretty.  If it has the typical engine bearer arrangement, then the engine mounting is integral with the fuselage.  This provides a lot of strength for the weight, which is prized in stunter construction.
Offline Hoss Cain
« Reply #2 on: June 24, 2011, 10:04:16 PM »
Thanks much for the reply.  I thought that looks just may be the main reason.
The engine bearer is a good point, however so few airplanes use that anymore, I think I can do just as well with properly supported firewall mounting. While Stunters do use many high "G"s in the maneuvers both positive and negative, so do a lot of other models, especially Pylon Racers. When I did that, I broke a few wings, but never had a firewall come off.
Of course there are some of these RC ARFs that have engines come off the front, firewall and all. Too bad some of those guys know so little about stress and G loads, but they learn fast when the fingers and hand parts depart the body.  :-[
Horrace Cain
Offline Lauri Malila
« Reply #3 on: June 25, 2011, 01:53:38 AM »
It's not as pretty.
 Well, it depends. :)
 One nice thing with a side mounted engine is that you can have the fuel tank position more "in", in relation to needle valve position. With engines like Retro, that has a big effect to engine run. It helps in wind, because it richens the engine when model likes to speed up, and also gives more speed when flying overhead. L
Offline Hoss Cain
« Reply #4 on: June 25, 2011, 10:21:22 PM »
WOW! WOW!  That side mounted engine is in one beautiful machine. Far too advanced workmanship for me. Thanks for showing it, Mr. Wescott.
The pic, came on great, but the Tank picture would not increase enough to read it.
Horrace Cain
Offline Paul Allen
« Reply #5 on: June 26, 2011, 12:34:34 AM »
Lauri
      Can you re post the tank drawing a bit bigger please.
« Reply #6 on: June 26, 2011, 03:16:12 AM »
 Oh sorry, I did not notice that.
 I don't know how to make it bigger but please give your Email adress, I'll send it over there. L
Offline Jim Thomerson
« Reply #7 on: June 26, 2011, 11:21:02 AM »
My only bad experience with side mounted engines was with K&B 4011's in stunt airplanes.  They ran to suit me mounted either upright or inverted.  However, On two different airplanes, I could not get them to run to suit me when side mounted.
Offline Chris Wilson
« Reply #8 on: June 26, 2011, 06:35:23 PM »
Well side mounting can give a better run with diesels (they also become easier to clear a flooded engine that way) and four strokes.
And it will also give more weight to the outboard side of the model and this in turn can reduce the amount of tip weight that is needed to be carried.
Also lends itself to inline designs very well - all inline means the thrust  line, wing chord and tail plane are all on the same line but it can look a bit plain and ordinary unless you have the finishing skills of Lauri! (Having the thrustline, wing and tail plane on different lines tends to be the more visually interesting in my opinion.)
The 'look' thing is very subjective, some modelers like the engine to be visible - some do not, some modelers like the horizontal lines broken up and to others it doesn't  matter but with all inline models you will need slightly longer landing legs as the thrust line will be lower than an inverted setup and that's the only negative I can think of really.
I do have a profile Cardinal that has a side mounted engine and it has the thrust line raised just like its full fuselage cousin and it does indeed look more appealing.
Cheers.
MAAA AUS 73427
Offline Peter Nevai
    • C3EL
« Reply #9 on: June 27, 2011, 02:18:38 PM »
Inside my minds eye, I just see all sorts of tank, and needle valve locating issues while keeping the structural integrity of the nose section high. You may find that in the end you wind up unacceptably nose heavy.
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #10 on: June 29, 2011, 10:40:05 AM »
The trick to side mounting an engine in a built up fuselage is to use an RC engine mount mounted to a 1/4 inch firewall. This eliminates the hardwood engine bearers and gives you a tank compartment without obstructions. I have built 3 airplanes running Saito 56/62's this way and all 3 have worked out well, the last one was good enough to win Advanced at Brodak this year. For four strokes I like the two piece SIG mounts as they allow the carb to be positioned all the way back to the firewall.
Offline Hoss Cain
« Reply #11 on: June 29, 2011, 09:47:38 PM »
Lots of good experience/s here. Real food for thought.
Jim T. :  Having a senior moment here. Was the 4011 the older K&B Series 61 and Series 64 .40 and .45? IMO if you got one of those to run OK for a CL stunter, then you did far better than me. I used a couple for FF but I had no need for such an engine in CL.  However they could haul a Starduster 900 up like a rocket.  #^
I never flew competition stunt with a side mounted engine. However I think this fall that will change. Thanks, Posters, for the data base.  ;D
Horrace Cain
« Reply #12 on: June 29, 2011, 10:25:41 PM »
Another 'trick' is seen on the last side mounted version of the English Freebird, 1/2" square bearers set for 2º out thrust will taper them back hard against inboard side of the fuselage so its plenty strong.
This will leave 35 mm between the bearers for a tank and this should be large enough for most engines.
MAAA AUS 73427
