  • July 12, 2025, 08:03:20 AM
Author Topic: Saito .40 C/L Dimensions  (Read 1294 times)
« on: August 13, 2008, 04:58:30 PM »
 I'm needing to get the mounting and shaft length dimensions etc. for the new Saito .40 C/L. Ideally, if someone could provide me with a copy of the schematic drawing showing all dimensions that might come with the engine, that would be GREATLY appreciated. I'm looking to possibly switch to this engine on a current project.
 Thank you!
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Saito .40 C/L Dimensions
« Reply #1 on: August 15, 2008, 08:00:30 AM »
I am pretty sure you can find a drawing with dimensions on Horizon Hobbies web site.. Or maybe a Saito site.. Google might come up with something...
Offline PeteBergstrom
« Reply #2 on: August 16, 2008, 08:36:40 PM »
Here is the site for the manual that comes with the engine.  It should have all the info you need.  Hope this helps!
Pete
http://www.horizonhobby.com/ProdInfo/Files/SAITO_Small-Medium_single_cylinder_Manual.pdf
« Reply #3 on: August 20, 2008, 05:23:11 PM »
 Thanks for the help guys, but all I've found through those avenues so far is info up to '06 on R/C versions. Is the new C/L engine in the same case as the current .40 R/C version?
Online Gordon Tarbell
« Reply #4 on: August 20, 2008, 09:28:06 PM »
supposed to be same case , same every thing except carb and maybe muffler. The dimensions are the same . I can send the paperwork out of one of mine sitting on the shelf. ( I know " Why isn't it in a plane yet?") send me an address to mail it to you, then mail it back after you are done. I am in Sacramento CA area .
Gordon Tarbell AMA 15019
« Reply #5 on: August 22, 2008, 05:14:08 PM »
 Gordon,
 Please check your messages, I left you a PM.
 Thanks!
« Reply #6 on: August 22, 2008, 06:03:21 PM »
went out with Fridays mail . You should get it probably Thur.    page 17 is what you want I think.
