  • June 16, 2025, 06:00:02 AM
Author Topic: Saito 30 airplane choice?  (Read 1072 times)
Offline Ken Deboy
    • Silk and Dope
« on: October 13, 2006, 10:35:48 AM »
What size airplane would be a good match for a Saito 30? I'm thinking of scaling down the wing and stab of a Cardinal and using them to make a "sorta scale" PT-19. What wing area and weight should I be shooting for? Maybe I should mention my flying field is at about 4500' elevation...
thanks,
There is a fine line between "hobby" and "mental illness"
Offline Bob Zambelli
Re: Saito 30 airplane choice?
« Reply #1 on: October 13, 2006, 10:47:12 AM »
Ken - see some of the other posts I've made regarding the SAITO .30.
Think about the Cardinette - around 420 square inches, 75% Cardinal aerodynamics.
Flies like a dream.
Offline Ken Deboy
    • Silk and Dope
« Reply #2 on: October 13, 2006, 12:38:48 PM »
Do you know if the Cardinette will be available as a kit, or only as an ARF?
thanks,
« Reply #3 on: October 13, 2006, 12:49:51 PM »
Ken - at this point, I'm not sure. I favor a kit as it is so straightforward to build. Look for  my construction article in the premier issue of CL World.
However, I have the AFR prototype in my shop now and it really looks good.
Stay tuned.
HOWEVER, If you wish to scratchbuild - I did the first one in around two weeks - you can take the Cardinal Evolution plans and reduce them to 82%. That's what I did and it was perfect.
