  • June 21, 2025, 12:02:28 PM
Author Topic: fox 35 rebuild  (Read 2367 times)
Offline bob lindsay
fox 35 rebuild
« on: February 20, 2007, 11:10:57 AM »
     Iam the proud owner of a fox 35 silver anniversary enguines . I want to re build it . I have a smith hemi head
   and zoot crank also stufferand abc piston and sleeve .I am sure i can put it together but my question is on the
   pinch at the top of the sleeve. it is my first experience with the abc and i dont want to screw it up any advise
   would be appreciated      Bob Lindsay ~>
Offline Ken Deboy
    • Silk and Dope
Re: fox 35 rebuild
« Reply #1 on: February 20, 2007, 06:35:30 PM »
Bob,
You might try contacting Lew Woolard. I sent a Stunt 35 to him with all the pieces you mention except the ABC piston/liner. For not much money, he not only assembled the parts, he also checks fits and clearances (he ended up replacing my P/L), trued up the mounting lugs, polished the venturi, and replaced all the screws with hex head screws.
cheers,
There is a fine line between "hobby" and "mental illness"
Offline bob lindsay
Re: fox 35 rebuild
« Reply #2 on: February 21, 2007, 09:20:45 AM »
 Ken, where do i find Lew? ??? Thanks  #^
Offline Dick Fowler
Re: fox 35 rebuild
« Reply #3 on: February 21, 2007, 09:29:03 AM »
This question is really directed more toward Randy. What is the impact of using your improved Fox .35 crank with an ABC piston/sleeve? Wasn't the counterweighting designed around an iron piston?
Dick Fowler AMA 144077
Kent, OH
Offline Bill Gruby
Re: fox 35 rebuild
« Reply #4 on: February 21, 2007, 10:38:47 AM »
Bob;
Lew woolard
3025 Locust
Wichita, Kansas   67216
(316) 529-1302
silverfox@hotmail.com
Thats it OK                   "Billy G"   H^^
Bill Gruby
AMA 94433
MECA 5393-10
Online RandySmith
Re: fox 35 rebuild
« Reply #5 on: February 21, 2007, 10:55:37 AM »
Hi Dick
The HZ crank works very well with both the iron or ABC setup. I didn't see where he was asking about the crank, just the pinch of the ABC piston and sleeve, which is a hard thing to explain in a chat box. I doubt that FOX would have fitted it so tight that it is a problem, however if they did you can wearout the small little bushing FOX uses for the motor. and damage the rod.
Online RandySmith
Re: fox 35 rebuild
« Reply #6 on: February 21, 2007, 10:58:19 AM »
HI BOb
You can read my reply to Dick above concerning the crank and P\S, and  if your concerned about the fits I would be willing to assemble  the motor for you , They are not hard to do but it is hard to explain fits here.
If I can help let me know, it would be no problem at all
Offline Ken Deboy
    • Silk and Dope
Re: fox 35 rebuild
« Reply #7 on: February 21, 2007, 11:32:32 AM »
Uhm... I meant Larry Foster did the work on my engine. From what I've heard Lew Woolard and Randy Smith also do good work on the Stunt 35s. I have no direct experience with either, though I did purchase my Hi Zoot crank and Hemi head from Randy. Randy also sells a PA style NVA that is custom made for the Fox and will work better than the stock NVA.
cheers,
Online RandySmith
Re: fox 35 rebuild
« Reply #8 on: February 28, 2007, 12:02:54 PM »
Hi Bob
Your motor is ready
can you  send me an email  so I can get your  email address?
« Last Edit: February 28, 2007, 03:00:55 PM by RandySmith »
Offline Marvin Denny
Re: fox 35 rebuild
« Reply #9 on: February 28, 2007, 02:08:29 PM »
Bob;
Lew woolard
3025 Locust
(316) 529-1302
  Lew,s E-Mail is probably not working.  You will probably have to either snail mail him or call him on the Ma Bell.  Call before 7:30 PM central as he goes to bed early.  (got to get his  beauty sleep)  (G)
  Bigiron
marvin Denny  AMA  499
