  • June 14, 2025, 05:04:12 PM
Author Topic: .. Royal 28...  (Read 2091 times)
Offline Bootlegger
.. Royal 28...
« on: December 02, 2016, 08:05:18 AM »
  My wife won a Royal 28 engine at our Oct contest and I want to gather some info, such as prop size, plug, fuel and anything else that some of you guy's can suggest on running it.
  Thanks a lot, oh what Models would be good to build for it also...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Russell Shaffer
Re: .. Royal 28...
« Reply #1 on: December 02, 2016, 08:37:43 AM »
A Flite Streak makes a pretty good engine test bed.  It will fly (not well) with a very anemic 19 and if the engine turns out to be a screamer it will speed up a lot but still be stable and controllable.  A fun airplane.
Russell Shaffer
Klamath Falls, Oregon
Re: .. Royal 28...
« Reply #2 on: December 02, 2016, 03:18:37 PM »
Any of the Brodak warbirds would be good. I think the Mauler is on sale.
Online RandySmith
Re: .. Royal 28...
« Reply #3 on: December 02, 2016, 03:54:08 PM »
put it on a Miss Sarah
Offline Bootlegger
Re: .. Royal 28...
« Reply #4 on: December 02, 2016, 06:40:22 PM »
  Any suggestions on running it?  Sorta like a .25 engine, 9x4 or such?  Again thanks...
Gil Causey
AMA# 6964
Re: .. Royal 28...
« Reply #5 on: December 02, 2016, 06:53:34 PM »
  I would try running it like an LA or FP.25 in any airplane that you have rad on here that people us those engines on. Get a Ringmaster for it. Everyone needs a Ringmaster so you can join in on the Brotherhood of the Ring Fly -A-Thon each year! Try anything from a a 9-4, 9-5 to 2 10-4. I generally use a 10-4 on my .25's spun up to the 10,000 RPM range. Same with the fuel, unless it's an old iron engine. I have two Royal .25 NIB put away I need to get out and play with some day. They have carbs on them but I'm hoping OS stuff fits them.
Online RandySmith
Re: .. Royal 28...
« Reply #6 on: December 02, 2016, 08:27:44 PM »
Run it in a  wet  2 cycle  , around a  4 pitch  prop   9, 9.5  , 10 inch
