  • June 21, 2025, 07:35:11 PM
Author Topic: OS VF Engines  (Read 1355 times)
Offline Ralph Wenzel (d)
OS VF Engines
« on: August 07, 2008, 04:40:25 PM »
The OS VF .25, .40, and .46 are all well-respected powerplants. What of the VF.61? Can it be made to run the same way?
Ralph Wenzel
AMA 495785 League City, TX
Online Brian Hampton
Re: OS VF Engines
« Reply #1 on: August 10, 2008, 03:36:32 AM »
Well I was totally ignored with an answer I gave in "the other" CL forum so we'll see what happens here. The 61VF has slightly higher port timings compared to the 40/46 VF's but I doubt it's enough to make much difference to the way the smaller ones run. Exhaust is 75 BBDC compared to 71 while the transfers are 62 compared to 60. There's a small difference in crankshaft timings too by a couple of degrees but nothing to write home about. My 61 weighs 18.9 ounces with exhaust stub and RC carb while the 46 is 12.8 ounces with stub and RC carb. I've only run mine on the bench so far but it handles beautifully with one flick starts hot or cold at full throttle on zero nitro fuel. Mine will end up in a stunter some time....
Offline Jim Oliver
Re: OS VF Engines
« Reply #2 on: August 10, 2008, 07:44:04 AM »
Brian,
I have several RC pattern type engines---some screamers and some strokers.  Mostly NIB, with no game in town, at least not one I want to play.
I guess some of them can be made to work for CLPA---just not sure if its worth the effort for me.  I need something that's pretty much a plug-and-play deal.  For the experimenter type they could be lots of fun......
Cheers,
Jim
Jim Oliver
AMA 18475
Re: OS VF Engines
« Reply #3 on: September 02, 2008, 10:43:17 AM »
Hi Ralph,
I have never seen a VF 61, much less seen one used in CLPA, sorry.  We did use the VF 40s for a long time, though. ;D
Bill <><
Re: OS VF Engines
« Reply #4 on: September 02, 2008, 05:39:08 PM »
Ralph Wenzel
Re: OS VF Engines
« Reply #5 on: September 08, 2008, 09:30:18 AM »
Please see:
http://www.rcuniverse.com/market/searchResults.cfm?requesttimeout=60
They do exist . . .
Ralph
LOL!!!!!!!
I know they exist, I have just never seen one, personally.  There are no R/C pattern fliers left around here that I know of, and I neve3r had a need for one........
Mongo
