What would be a good starting point 2 or 3 blade prop for a Tempest II / PA 51 Pipe combo and the advantages or not between 2 or 3 blade and brands available. Thank You Walt
HI Walt
The Bolly 12.2 x 4.2 2 blade and the Bolly 12 x 4.25 3 blade are the best to start, This is what I use on my 51 and are excellent choices.
Both have advantages and disadvantages, just a few are :
three blades are quieter, the are also a little less prone to wind whip up , and sometimes are more of a constant speed. Two blades are easier to turn, are lighter, cycle faster 4\2 , load the motor less
I can use either with great results, just have a little bit differant setup with the two differant props
