  • June 19, 2025, 09:08:37 PM
Author Topic: Saito carb clearance on profile?  (Read 852 times)
Offline Ken Deboy
    • Silk and Dope
« on: October 28, 2006, 09:19:38 PM »
I'm getting ready to mount a Saito 30 on a Ringmaster and I noticed there is a gap of only about 1/4" between the fuselage side and the carb opening. Is that enough or do I need to relieve the fuse side to give more room for air to get into the carb?
thanks,
There is a fine line between "hobby" and "mental illness"
Offline Leester
Re: Saito carb clearance on profile?
« Reply #1 on: October 28, 2006, 09:32:53 PM »
Ken: Go to product reviews under Saito 30 and go down to a pic of Bob Z's Saito on a profile will give you an idea.
Leester
ama 830538
Offline Bob Zambelli
« Reply #2 on: October 30, 2006, 12:23:30 PM »
Guys - the picture I posted is my OS .40 on the profile.
BUT, I've run the SAITO .30 on a number of profiles and 1/4 inch clearance should be plenty for breathing.
I usually drill a 1/4" hole through the fuselage such that I can prime the carb from the inboard side.
On the larger engines, you can usually put your smallest finger over the venturi and choke it.
« Reply #3 on: October 31, 2006, 09:44:03 AM »
It'll be fine as is. y1 (air is really small, it can get into, and through, incredibly small places. ;))
