  • July 17, 2025, 08:14:38 PM
Author Topic: Rear bearing for OS 40 VF  (Read 878 times)
Offline Fred Quedenfeld jr
« on: April 16, 2019, 07:32:48 AM »
What is the correct bearing  I want to get away from the steel or brass ball keeper
Fred Q
Re: Rear bearing for OS 40 VF
« Reply #1 on: April 16, 2019, 09:17:35 AM »
Fred Q
   It's an oddball size, unique to OS, but now available from Boca Bearings. I am also sure Randy has some.
p.s. https://www.bocabearings.com/products/bearing-applications/rc-engine-bearings?ProductType=2&ItemMakes=OS_ENGINES&ItemModels=VF_ABC_RC&ItemFeatures=40
    I always use the cheapest variety, even the low-end bearings are much better than the stock units (although the stock bearings are generally OK for a very very long time).  But you can certainly get more expensive bearings for it, $90 for a bearing set on a $125 engine - even if it is the best-ever $125 engine - it a bit much for my blood. I am both an engineer and a stunt flier, so I can't really help being cheap...
« Last Edit: April 16, 2019, 09:39:22 AM by Brett Buck »
« Reply #2 on: April 16, 2019, 12:34:36 PM »
Fred Q
I have the correct  real bearing for it, many people have got the almost right bearing  but they were 1mm too thin
Mine are  hi speed  phenolic cage  bearings, I also have  sealed  fronts for the  VF as well as many other parts
Randy  678 407 9376
