Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 23, 2025, 07:34:37 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
fox needle valves
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: fox needle valves (Read 787 times)
philip metzner
chevyiron420
Trade Count:
0
Lieutenant
fox needle valves
on:
June 01, 2010, 11:47:40 PM »
Several years ago i bought two new NVA's for my fox .35's. The ones i got have two holes in the spray bar. They are so sloppy in the threads the engines wont run without a piece of fuel line fitted tight between the needle and spray bar. I have two of the original brass spray bars and fox tells me they have new needles to fit them. Do you think that would be any better, or just a waste?
Logged
Geoff Goodworth
Trade Count:
0
Captain
Re: fox needle valves
Reply #1 on:
June 02, 2010, 05:44:10 AM »
Philip, I suggest that if you want to repolace the factory Fox NVAs, use the excellent NVA that Randy Smith produces for the Fox 35.
It's a straight drop in but it is turned down to retain the correct venturi throat area.
Cheers, Geoff
Logged
Jim Thomerson
Trade Count:
0
Admiral
Reply #2 on:
June 03, 2010, 02:19:17 PM »
I've been running stock Super Tigre NVA's in my Fox stunt 35's for years. I could not get a consistent run with the Fox NVA.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
fox needle valves
