  • July 05, 2025, 05:50:34 AM
Author Topic: Props. which one is best?  (Read 3355 times)
Offline phil myers
« on: May 10, 2010, 01:34:40 PM »
OK, here's the thing.. I tried 3 different props on my asp.21 all 9x4 and got various rev readings! Props used:
1/ Graupner 9x4......11,700 rpm
2/ APC 9x4.............12300  "
3/ Kavan 9x4..........13300  "
 I'm guessing the Kavan (yellow plastic) has distorted at high revs, perhaps reducing the pitch so increasing the revs but I don't know for sure, but the other 2 are as hard as nails, so what is this telling me?  Also , the asp .21 is tricky to start, when flicking the prop (engine on bench stand) the engine revs like a motorbike throttle being blipped for 10 secs then dies. Does this half dozen times before finally going?Would appreciate any advice on these issues please.... Thanks Phil.
Re: Props. which one is best?
« Reply #1 on: May 10, 2010, 02:40:08 PM »
It tells you that different companies specify and produce their propellers different, with different interpretations of the word "pitch" (although "diameter" is unambiguous enough that I wouldn't expect much variation).
Now if you try a dozen "identical" props from those same three manufacturers, you'll find out about manufacturing variation as well.
Diameter and pitch only tell part of the story.  The area of each blade, the variation in the width of the blade over the diameter, the tip shape, and the distribution of the blade angle all affect the propeller performance.  I wouldn't be surprised if the surface finish didn't play an important part, too, at least for some props.  Add to that the fact that some props will bend and unload (like your Kavan), and you have lots of variables that are all hidden behind those two innocent-looking numbers.
Top Flight used to sell "regular" wood props and "power" wood props which were basically the same only with a narrower blade -- and they performed differently.
Now forget to balance the props and suddenly you've got another whole set of variables (you did balance them, didn't you?).  A poorly balanced prop will sap power from the engine, generally make your whole setup act strange (except, possibly, at startup), and shorten the life of airframe and engine.
« Reply #2 on: May 10, 2010, 03:28:24 PM »
Both the Graupner and APC props are "good stuff".  The 9-4's of both work quite well on the .25LA...possibly the Graupner would work on the .21FP, but the APC is considered the standard.  I don't have a .21FP.  Dunno about the Kavan, but probably only fair...very close to being a clone of the old Grish Tornado nylon props, from the few I've seen (8-6's for D-Bat).
What you've learned is that they "load" the engine differently, but I'd put $ on both the Graupner and APC being pretty good in the air, if the size is appropriate, and it should be. It should be good for a Peacemaker or ARF Flite Streak. APC also makes a 9.5 x 4.5, which might be worth trying, IF you can get one.  I used a 9-4 Taipan on my Magnum XL .25, a relative of your ASP.  H^^ Steve
Offline Damian_Sheehy
« Reply #3 on: May 10, 2010, 05:02:16 PM »
Here's one other data-point that may influence the performance you are seeing:
Graupner 9x4   0.9oz
Kavan 9x4      0.55oz
I don't have stats for an APC, when I checked several of them in my LHS the hole was visibly offset.
I imagine the APC is lighter than the Kavan, both the APC and Graupner are fairly stiff, so the figures are not surprising. The Graupner has a higher moment of inertia (flywheel effect) and I personally find it makes manual starting much easier.
« Last Edit: May 10, 2010, 05:25:29 PM by Damian_Sheehy »
Offline Jim Thomerson
« Reply #4 on: May 10, 2010, 07:48:30 PM »
All said and done, the best prop is the one which works best on a particular engine in a particular airplane.  It is a matter of fly and try.
Offline phil myers
« Reply #5 on: May 11, 2010, 11:59:19 AM »
Thanks guys for the helpful replies.. I will of coarse try different props on the plane (ringmaster) when I've actually built it! That will be a winter project. And err..well no,.. I ermm didn't balance any of the props, Tim! And I know I should but I'm a lazy sillybilly.. Any ideas on the other point about the engine revving up and down before finally going? Many Thanks for the input..
Phil
« Reply #6 on: May 11, 2010, 05:05:42 PM »
Phil,
Can you provide more details? Is this a new engine? Is it broken in?
Did you prime to siphon the fuel into the carb before attaching the battery and attempting to start?
What type of tank are you using and what size is it? Is the tank full?
10 seconds before quitting should give you plenty of time to get around to the other side of the bench to make adjustments to the needle.
Damian
Offline phil myers
« Reply #7 on: May 12, 2010, 12:56:40 PM »
Damian, the motor has had 1hrs run time as per the instructions, Its fitted with the r/c carb and 4oz clunk tank on bench stand. Last year it ran fine so have checked fuel lines for leaks everything looks ok, I do choke and flip the prop untill I see fuel going into the carb then flip 2-3 more without finger choke, attatch glo clip and flick to start. Just thought, I used to fill the tank for running in, but have only been putting in about 2oz of fuel or less while testing various props! Could this be the problem?... I'll attempt to post a photo of my benchrun setup although this is of a ASP15s blue head I was running in over the winter (as you can see!) Thanks for any advice
Phil
Offline Paul Wood
« Reply #8 on: May 12, 2010, 04:31:19 PM »
Phil,
I also run R/C engines with the carb wired open.  (O.S. and Thunder Tigre)  If I use the electric starter, the engine will spin up to speed without any issues.  But, if I'm hand starting to protect the spinner, I often experience your situation.  I suspect it's the airflow in the venturi trying to get itself stabilized since these carbs are usually started at idle.  My technique: while the engine is sputtering, I tap my finger over the venturi and it quickly spools up.  Just watch that prop!!
« Reply #9 on: May 12, 2010, 06:22:56 PM »
Hi Phil,
I concur with Paul. It sounds like the engine is gasping for fuel.
It's not the problem per se, but it's consistent with the thought that the engine was struggling to get more fuel. If the tank were full it would provide a little more pressure head to get the flow into the carb. Instead the engine has to suck on the fuel a bit harder to get established. I am assuming you didn't change the needle setting since your full-tank run. Responding by temporarily opening the needle a little until it stabilized would have helped also, but I guess you didn't want to touch the needle setting in order to conduct your experiment.
Offline phil myers
« Reply #10 on: May 13, 2010, 02:43:34 AM »
My sincere thanks to Paul and Damian for your replies,
I will try again with a full tank next time and report back!!
Cheers Phil..
Offline phil myers
« Reply #11 on: May 13, 2010, 02:02:27 PM »
OK I tried that with a full tank and its no different. However, I closed the carb barrel and I mean closed (couldn't see any hole/gap down the venturi) and it started straight away!! When I opened the barrel again the motor died. Did this severel times so I'm guessing the r/c carb low end needle needs to be re-adjusted. Someone please tell me if I'm wrong...
Thanks Phil
« Reply #12 on: May 13, 2010, 03:05:16 PM »
I think that a 9/4 on a .21 sort of OK, but actually unrevving the engine somewhat.  For better results, go down a size or at least clip a 1/2" off one of your 9/4's see how you like it.
9/4 on a 21, yeah you can use it.  But I'd be happier with less prop and more RPM.
« Reply #13 on: May 13, 2010, 07:32:03 PM »
Phil,
I still believe the engine is not getting enough fuel and the way to rectify that is to open the main needle (CCW) a few more ticks and try again. When you close the throttle it acts like a choke; the engine is devoting more suction to fuel than to air. When you open the throttle the engine is getting way more oxygen and fuel is burning efficiently, it speeds up but the fuel isn't meeting the demand.
Are you comfortable/experienced adjusting the needle while the engine is running? Do you have the needle fixed at the current setting?
Let us know how it goes.
Damian
« Last Edit: May 13, 2010, 07:52:05 PM by Damian_Sheehy »
Offline Paul Wood
« Reply #14 on: May 14, 2010, 07:50:58 AM »
Phil,
If the engine started with the barrel closed, you've got an air leak.  It's usually at the base of the carb where it seats in the engine case.  I always seal this area with a bead of silicone.  The rubber o-ring is usually not sufficient without added sealing.  This may solve your problem.  If not, the low end setting is too rich if the engine sputters when you open the carb.  If it suddenly dies without sputtering, it's too lean.  The low end will have no effect on the high end and is really only used if you're going to idle the engine.  Also, most R/C engines will not idle well without the muffler baffle.  Check head and back plate bolts.  Seal the leaks and try starting the engine with the carb fully open using an electric starter.  Once you get the high end needle set, you're good to go.
Offline phil myers
« Reply #15 on: May 15, 2010, 09:23:18 AM »
 #^ Eureka!!  I found the problem (with a bit of help from the replies!) The fuel inlet nipple was cracked around the thread. I replaced the r/c carb with a control line venturi and it starts first flip every time. I'm so chuffed, its been bugging me for 2 weeks now. Thanks again for the advice..
Phil
« Reply #16 on: May 15, 2010, 04:09:22 PM »
Yet not one of us said "obviously you have a cracked fuel fitting!".
So -- have you chosen a prop?
Offline phil myers
« Reply #17 on: May 16, 2010, 08:55:45 AM »
True enough Tim, but I was put on the right track about an air leak, which made me take a closer look at all possible areas of a problem. I was prompted in the right direction!
I'll go with the Graupner, not as sharp as the APC.. Phil
