  • July 09, 2025, 04:35:32 AM
Author Topic: Props for ST.46  (Read 3066 times)
Offline James Holford
Props for ST.46
« on: April 09, 2019, 06:46:59 AM »
What is a good starting point for the Super Tigre G.21/46?
 I have one with a Big Art tube muffler that Im thinking of sticking on a Forerunner if the .46LA isnt enough for it (forerunner is a little porky in weight).
 11x4 on up?
Sent from my SM-G965U using Tapatalk
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Massimo Rimoldi
Re: Props for ST.46
« Reply #1 on: April 09, 2019, 08:12:27 AM »
Hi.
I don't think you'll have much luck with an 11x4 prop on a G21/46.
Depending on the type of ride you want, you may need something from 11x6 to about 12x5.5-6.
This obviously depends on the quantity of nitro, venturi diameter, head thickness, etc.etc.
I believe that by using the search engine here on SH and on SSW you can find a lot of valuable information about it.
Massimo
Re: Props for ST.46
« Reply #2 on: April 09, 2019, 09:24:04 AM »
 11x4 on up?
   No way on the 11-4. Like most things you can do with/to an ST46, I tried it on several occasions. It will spin fast enough to make llevel flight speed but will be deader than dead in the maneuvers.Not enough pitch.
    I would suggest starting with an 11-6, 11.5-6 and if everything is working, then try a 12-6.
Re: Props for ST.46
« Reply #3 on: April 09, 2019, 10:09:54 AM »
Oh ok cool. Appreciate the help!
Jamie Holford
Lafayette, La
AMA #1126767
Re: Props for ST.46
« Reply #4 on: April 09, 2019, 02:21:37 PM »
I run my 46LA on a rather large profile.  I have setted in on the MA 11-6.  I have tried 11-4, 11-5, 11-5.5, 12-5, 12-6 and a three blade 10-6.  It is happiest with the 11-6.  I did have decent results with a wood 12-6 cut down to 11.  Can't remember the brand.  An 11-5 works if you run on the lean side.  I don't.
Re: Props for ST.46
« Reply #5 on: April 09, 2019, 02:27:34 PM »
Yea I normally run TT 11x4.5 on my .46LA's.even 11.5x4 was great on the Cardinal i had.
 Never ran a ST.46 and figured since it was a .46 the props would be close to the same. But it is a totally different animal of a motor compared to the LA afterall.
Thanks!
Jamie Holford
Lafayette, La
AMA #1126767
Offline Dane Martin
  • heli pilot BHOR
Re: Props for ST.46
« Reply #6 on: April 09, 2019, 03:18:04 PM »
Thanks!
The ST chugs, where as the OS zings
Re: Props for ST.46
« Reply #7 on: April 09, 2019, 03:19:45 PM »
Hehe thats what I hear. I need to find a Big Art Tongue Muffler for it. I have that tube muffler but for weight sakes. I would assume the tongue muffler would be lighter.
Jamie Holford
Lafayette, La
AMA #1126767
Re: Props for ST.46
« Reply #8 on: April 10, 2019, 09:34:04 PM »
  James;
    Any muffler that fits a ST.51 and ST.60 will fit the .46 also. That will let you use a Scott Dinger or Randy Smith unit also. Both nice and light.  As for props, look for some of the classic wide props from Rev-Up. I haven't run a ST.46 in a long time, but I recall that it was suggested that the best prop was a 12-6 Rev-Up cut down to 11 1/2" or 11 3/4". I have liked the Xoar props on my ST.60, so if you can get some of their 11-6, 12-5 and 12-6 props, they may do the job for you. Nice props and not too expensive. And don't underestimate the Master Airscrew prop in the same dimensions. They have improved their product quite a bit and the ones I have been testing on Fox .35s and such have worked well for such a cheap prop. I have several good ST.46s and hope to build something nostalgic for one, just for the sound! With a good muffler and propped correctly, you'll love the sound! I think they are just like the ST.60, in that when you have the right prop, it tells you! Whether they are competitive or not, it's fun to run and fly them for the sound!
Re: Props for ST.46
« Reply #9 on: April 11, 2019, 09:00:36 PM »
from Elsewhere ;
Contrary to what many have said on this subject the St.46 can and does handle larger airplanes than one's with 600 sq. in. of wing area. The ST.46 was so versatile that you could open the engine up with a .300 venturi and tongue muffler and fly models as large as 700 sq.in. I did with the Magnum (89 Advanced Champion) and so did Billy Simon with his Scorpio and Les McDonald with his Stiletto 700 & 660 (Nats and World Champion), not to mention Billy Werwage and his USA-1 & Juno.
Having said that, the St .46 engine can be set up for just about any size model by changing the venturi size, type and size of the muffler, prop, and Nitro content in the fuel.
In my humble opinion still one of the best engines out there.
Mike Pratt
Offline Manuel Cortes
Re: Props for ST.46
« Reply #10 on: April 12, 2019, 09:04:03 AM »
Hi all, just for your interest, Merco silencers are a perfect match for ST46, the old three pieces one was hugely used in the ST60 golden era.
Kind regards from Spain.
  James;
Re: Props for ST.46
« Reply #11 on: April 12, 2019, 01:12:00 PM »
Well  ,  some  Merco  muffler  match perfectly, 1.502 inches ,many other are  1.445 inch and  match the  OS  SF  SX  series  plus  the magnum  52   52  ASP  46  52   etc
Re: Props for ST.46
« Reply #12 on: April 12, 2019, 07:34:01 PM »
Far and away the best prop I ever used on my ST .46s was a Rev Up 11 1/2 x6 EW.  Unless you can find a stash of these I’d try a light wood 12x6 and maybe nip off the tips to 11 1/2”.  The Tigre needs to run in a quick four cycle and breaking into a two cycle as the nose gets vertical.  This requires more pitch and lower RPM lest you will burn your rings in a hurry.  Don’t try anything like 4 pitch.  Don’t be afraid to use a little more oil in the fuel.  A lovely engine as long as you can find a supply of rings and bearings.  I’d think an 11x6 APC would be a fair fallback prop if that’s all you can find.  The ST .51 runs well on it but growls back at me with a 12x6.  It seems over propped with that.
Offline Chuck_Smith
Re: Props for ST.46
« Reply #13 on: April 21, 2019, 05:34:40 AM »
I've got to go with Dave on this.  The ST .46 with a Rev Up was  (IMHO) one of the power systems that opened the door from the early 70's and led the way to the modern ships of today. (Les McDonald not withstanding.)  And man, do they sound great. If it had a rear exhaust it would have been just about perfect.
AMA 76478
