  • June 21, 2025, 04:24:09 PM
Author Topic: OS thrust washer  (Read 1081 times)
Offline Terry Bolin
  • Havin' the time of our lives!
OS thrust washer
« on: November 04, 2006, 05:32:55 PM »
I am breaking down a OS40 SF for a good friend of mine and I am down to the crankcase and crankshaft. My question is : does the thrust washer just press of with a puller like it looks like. Looks to be a tapered seat. Has anyone been here before?
Thanks, Terry
Terrybolinracing@aol.com
Offline Greg L Bahrman
Re: OS thrust washer
« Reply #1 on: November 04, 2006, 05:58:57 PM »
The answer is yes. You can probably get a puller from Tower or maybe from a local friend. If not I think I have one you can borrow.
« Last Edit: November 05, 2006, 02:31:04 PM by Greg L Bahrman »
Greg Bahrman, AMA 312522
Simi Valley, Ca.
« Reply #2 on: November 05, 2006, 01:22:47 PM »
Thanks, Terry
Terry
It is a  pressed fit , it has a  tapered collet  and drive washer, it presses on when you tighten the props and  takes  a  puller  to get it off.
OS MAX  makes a puller for their engines  and  you can get them from tower, or you can use a  small  gear puller
« Last Edit: November 05, 2006, 02:59:07 PM by RandySmith »
Offline Regina Kelly
« Reply #3 on: November 05, 2006, 02:45:46 PM »
Central Hobbies sells a puller, which is actually a slightly modified battery terminal puller, for about $10.
Jim Oliver
