  • July 16, 2025, 01:21:34 AM
Author Topic: Prop size for a Saito 56  (Read 2485 times)
Offline Crist Rigotti
« on: May 20, 2006, 04:40:14 PM »
What size props do you guys use for the Saito 56?
Re: Prop size for a Saito 56
« Reply #1 on: May 20, 2006, 10:11:31 PM »
Hi Crist
I have sold many props for that engine. Paul Walker  used a  bolly 12 x 4.5  3 blade
many others  use  the bolly  13 x 6   or  13  x 5  2 blade
I have also had people use a 13 x 4.5  3 blade
REgards
Offline John Christensen
« Reply #2 on: May 23, 2006, 11:40:18 AM »
Up here Keith is using a Rev-Up 12-5 at about 10400 RPMs and I use a Zinger 12-5 at about 9700 RPMs.
Offline Doug Moon
« Reply #3 on: June 07, 2006, 09:58:34 PM »
I ran an Eather 14X4.5 2 blade with the large venturi at 8800.  It was a beast!  No GP in the corners either with the lower RPMs.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
« Reply #4 on: June 07, 2006, 10:25:40 PM »
Doug,
Was that a flat back prop?
Offline Doug Moon
« Reply #5 on: June 16, 2006, 09:31:08 PM »
Yes it was a flatback prop.  I have ran the 1/2 UC as well with very good results.
Tric to this setup was the very large venturi.  The motor was really breathing well and 8800rpms was really right in the strong power range for that motor.
Doug Moon
AMA 496454
« Reply #6 on: June 17, 2006, 07:44:32 AM »
Thanks Doug.  Not sure what you mean by "1/2 UC"?  UC =undercambered but the 1/2 stumps me.
Offline Doug Moon
« Reply #7 on: June 17, 2006, 09:26:04 PM »
Crist,
!/2 means he just barely UCs the prop.  Just enough to know it is there.  Full undercamber is twice as much.  Eather is very exact in how he produces he props.  You can count on 1/2 UC being exactly half the normal amount if UC.
I hope this helps.
Doug Moon
AMA 496454
Online Gordon Tarbell
« Reply #8 on: June 18, 2006, 07:17:29 AM »
What size plane is this Saito 56 /14"prop flying?
Gordon Tarbell AMA 15019
« Reply #9 on: June 18, 2006, 01:30:58 PM »
Doug,
Thanks for the clarification.
« Reply #10 on: June 20, 2006, 12:17:10 PM »
I sure tried a lot of different props on a Saito 56. The only rule I discoved is that it's entirely dependent on the plane/engine combination. I built a plane and went through probably 30 props before I tried this 12x4 eather 3 blade UC prop. This particular one really made the plane come alive with the Saito 56. I transferred the entire setup; engine, prop and tank to the next version of the same design. Only a very few changes in the the airframe and of comparable weights. It flew OK with that prop, but nothing to write home about. Went through another 30 2 and 3 blade props from 11" to 13.5 inches. and finally settled on an 11.5 x 4.25 three blade Eather. It was cut down from a 14x4 so had really wide blades. Worked very well.
