  • July 08, 2025, 03:36:49 AM
Author Topic: Prop question  (Read 3358 times)
Offline Tim Chenevert
Prop question
« on: December 21, 2017, 02:21:26 PM »
I am building a stock Sig Twister with a Tower 40 engine on it. A 10.5x4.5 prop was suggested but are not available locally. Is there a more available prop or should I look for this one? Tim
Baton Rouge Bi-Liners
AMA 179681
Offline Brad LaPointe
Re: Prop question
« Reply #1 on: December 21, 2017, 02:47:59 PM »
11x4 APC is close and available most places . Check Tower , they have most props in stock. 11.5x4 APC works well also .
Brad
Offline Target
  • C/L Addict
Re: Prop question
« Reply #2 on: December 21, 2017, 03:23:13 PM »
I have had great luck with the Xoar wood props. For your tower .40, an 11x4 or 11x5 should work well.
Use the 11x4 if you are running the engine in a rich 2 cycle mode, and use the 11x5 if you are able to get the engine to do the 4-2-4 cycle thing that some people like.
I'm excited for you for the maiden flight!
Chris
AMA 5956
Re: Prop question
« Reply #3 on: December 21, 2017, 05:09:23 PM »
Just checked Brodal’s site and no go on that propeller either.  Tim
AMA 179681
Offline Target
  • C/L Addict
Re: Prop question
« Reply #4 on: December 21, 2017, 05:31:46 PM »
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXAPLP           xoar 11x5
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXAPLJ&P=6   xoar 10x5
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXAPLN&P=6  xoar 11x4 on backorder until late Dec (Now?)
The APC props work good, but they are heavier than the wood props by quite a bit.
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LX1555
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXEZLS&P=7
I love the xoar 10x5 on my Banshee with a FP.40. Flies great.
Chris
AMA 5956
Re: Prop question
« Reply #5 on: December 21, 2017, 05:37:01 PM »
Central Hobby in Billings, MT and the APC factory are THE places to get ALL of the APC props. It seems nutzo to go to all the trouble to get a prop just to try, but that's the world we CL guys live in. There have been enough reports of good results with the .40FP, that I'd get 3 or 4. But i admit that I may have a propeller fetish...   ;D  Steve
Offline big ron
Re: Prop question
« Reply #6 on: December 22, 2017, 06:11:23 AM »
Tim i have a few of the 10.5x4.5's if you want to try them, also have many others we can try. After today i don't go back to work until 1-3-18 if you can go during this time let me know. I have a tower 40 on my twister with a 10x5 APC runs good i need to try some other props too.
John Blanchard
Brusly, Louisiana
 AMA 1054488
Re: Prop question
« Reply #7 on: December 22, 2017, 03:57:47 PM »
Thanks Ron! I am off until Wednesday but still have to finish the Twister. Real close now with just putting the control horns on and wings, stab and rudder. Gill suggested the 10.5x4.5 but hard to find. I was leanining towards the 10x5 as they are readily available. Is anyone flying this weekend? Tim
AMA 179681
Offline big ron
Re: Prop question
« Reply #8 on: December 22, 2017, 07:54:05 PM »
Not sure if anyone is going this weekend I can't make it got to catch up around the house. Maybe we can Tuesday if weather will cooperate.
John Blanchard
Brusly, Louisiana
 AMA 1054488
Re: Prop question
« Reply #9 on: December 30, 2017, 03:45:47 AM »
Thanks John for the props to try! Ringmaster is ready to go again. Going 10x5 on it instead of the 10x6. I had a great time flying Friday with everyone. Tim
AMA 179681
Offline Dennis Moritz
Prop question
« Reply #10 on: December 31, 2017, 10:31:47 AM »
10.5x4.5 apc prop can be ordered from Tower. Easy to get in the past. I've used that prop with Tower 40 engines on all kinds of planes. Busters, Flite Streaks, Magician, Vector 40, Tanager, Galaxy, Oriental, Prowler, RD1. Engines were tuned with Venturi, head gaskets and fuel. Planes weighed mid twenty ounces to high forty ounces. Oh yes. Also powered some Twisters of mine.
Re: Prop question
« Reply #11 on: January 01, 2018, 08:07:16 PM »
The old Tornado / Grish 11 x 4s woerk pretty well on them ( FPs ) if you find any ( at the swap meets etc 0 NOT the floppy polyethalene ones though .
come to think of it , the 10 x 4 3 blade would likely be good , if a bit revy , and a zinger 11 x 4 would have to be ok , and ' tuneable ' whittled .
Re: Prop question
« Reply #12 on: January 02, 2018, 04:16:43 AM »
Thanks on the info on the props. Going to try the 10.5x4.5 prop on my Twister. Tim
AMA 179681
