  • July 09, 2025, 05:08:35 AM
Author Topic: ST G-51 and prop fit  (Read 2257 times)
Offline Leester
« on: June 25, 2006, 07:48:38 PM »
I started to bench run my ST G-51 today. As per the instructions I got a 11-6 prop (T/F) my prop reamer doesn't make a whole the same size as the ST uses, it is just a little larger. I think I heard somewhere using a drill is a no no,so what do you use to make the whole fit or do you bush the prop? If so what with?  Thanks
Leester
ama 830538
Offline Wayne J. Buran
Re: ST G-51 and prop fit
« Reply #1 on: June 25, 2006, 08:46:41 PM »
Use a Fox metric  prop reamer. The section behind the threaded area is 7MM. Hence if you are using a Tru-Turn spinner assembly you need to use a 7MM bushing.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
« Reply #2 on: June 26, 2006, 12:29:46 AM »
I only reamed out the back side of the prop enough to fit the propeller over the hump.  This left enough of the front section of the hub to center on the therads.
If that doesn't work for you, get a metric reamer like wayne said!  y1 ;D
« Reply #3 on: July 14, 2006, 11:20:38 PM »
I first bought a step reamer, but didn't like it. Some guy named Scott Riece recommended a traditional tapered hand reamer, which I like a lot better. It takes a few seconds to cut & test, then cut & test again, but after a little experience, it's not a problem. The fit is better and one tool does it all.  :D Steve
« Last Edit: July 22, 2006, 09:22:37 PM by Steve Helmick »
Offline peabody
« Reply #4 on: July 15, 2006, 12:17:32 PM »
I think that you've got way too much pitch for that engine.....most have good luck with 11 and 11.5 X 4 APCs...
Top Flite writes their instructions with r/c types in mind....
Offline Leester
« Reply #5 on: July 15, 2006, 05:30:12 PM »
Thanks Rich: I was just going by Super Tigres break in procedures, but as you say it's for R/C they don't mention C/L.
Leester
ama 830538
« Reply #6 on: July 16, 2006, 05:24:50 PM »
Mine always likes a Rev Up 12-5 Govt. Surplus prop.   y1
I start with one of those everytime I put the ST 51 in a new plane.  x:
Bill <><
Offline Jim Oliver
« Reply #7 on: July 16, 2006, 07:22:54 PM »
Is there a source of the surplus Rev-Up 12x5?
Jim
Jim Oliver
AMA 18475
« Reply #8 on: July 16, 2006, 09:47:42 PM »
Hi Jim,
They pop up on ebay from time to time.  My "local" Hobby Shop (about an hour away in Fyetteville-near Pope AFB) had a supply of them several years ago.  They were used on foam R/C drones, IIRC.
Bill <><
Offline dennis lipsett
« Reply #9 on: July 18, 2006, 07:00:38 PM »
I just bought 2 packages of these off the bay a few weeks ago. Price was reasonable and you just cant beat the brand can you..
Bill is right this is a great prop for the ST51.
