Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
June 17, 2025, 08:19:23 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Parts? Leo .15 & Ofna .12
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Parts? Leo .15 & Ofna .12 (Read 1626 times)
Terry Caron
2017
Trade Count:
0
Admiral
on:
November 22, 2014, 06:34:28 PM »
Hi all -
I got these ABC engines in a "grab box" of mostly RC car stuff and, not being familiar with either brand, hope someone can point me to a source for parts.........
if they're worth the trouble.
The Leo's used but the piston still has top pinch so I suspect it's OK; needs a prop driver and nut.
The Ofna appears new (except for a bit of black paint loss here and there) and unmounted; it's missing the head and possibly shim/gasket.
Anyone familiar with them?
TNX.
Terry
Last Edit: November 22, 2014, 07:07:16 PM by Terry Caron
Logged
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Steve Helmick
24 supporter
Trade Count:
0
Admiral
Re: Parts? Leo .15 & Ofna .12
Reply #1 on:
November 22, 2014, 10:05:25 PM »
You might check with "Just Engines" in England for the Leo parts...if JE is still in business. Otherwise, see if OS parts will fit. I believe they're made in either Taiwan or PRC...should say on the case.
The Ofna parts should be available from your local R/C car shop or Tower Hobby or other online source for R/C car parts.
Logged
In 1944 18-20 year old's stormed beaches, and parachuted behind enemy lines to almost certain death. In 2015 18-20 year old's need safe zones so people don't hurt their feelings.
Terry Caron
2017
Trade Count:
0
Admiral
Reply #2 on:
November 22, 2014, 11:39:53 PM »
Hi Steve -
J E doesn't sell Leo now and lists no parts for them.
This Ofna is likely an older series - crankcase doesn't look like the current car versions - but haven't found a parts source for the new ones either.
May be a better idea to sell them as RC car parts anyhoo.
Terry
Logged
AMA 249824
NRA Life Member
Terry Caron
2017
Trade Count:
0
Admiral
Reply #3 on:
November 23, 2014, 10:01:37 PM »
Another possibility -
I measured the Leo .15 crankshaft at the prop driver seat and it's .305 & .285 on the flat - way smaller than OS.
Anyone willing to measure your .10 - .19 shafts to see if any match?
Tnx.
Terry
Logged
AMA 249824
NRA Life Member
GregArdill
Trade Count:
0
Commander
Reply #4 on:
November 24, 2014, 02:59:20 AM »
Terry.
It's possible that the Ofna is a car engine and originally had a heat sink head. You'd probably need to have a replacement made for Aeroplane use. Or else find something with matching bore and fit that, although there may still be some machining involved.
Good luck
Greg
Logged
Terry Caron
2017
Trade Count:
0
Admiral
Reply #5 on:
November 24, 2014, 10:49:52 AM »
I suspect you're right Greg, as all reference I found to Ofna is car-related.
However, I have both heads for the Leo, so it's only issue is a prop driver - I hope someone can match the dimensions to a replacement.
Terry
Logged
AMA 249824
NRA Life Member
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
