  • June 22, 2025, 03:15:43 AM
Author Topic: Pipe tuning  (Read 868 times)
Offline Allan Perret
  • Proverbs
Pipe tuning
« on: June 11, 2009, 05:25:20 PM »
Setting up the length, do you cut the header or the pipe or both ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline John Miller
Re: Pipe tuning
« Reply #1 on: June 11, 2009, 06:26:14 PM »
I believe it's better to cut the pipe, after removing the metallic liner some have. If you cut the header, the glass pipe gets closer to the extreme heat, and has more of a chance of melting, getting soft, collapsing.  H^^
Offline Jim Oliver
Re: Pipe tuning
« Reply #2 on: June 11, 2009, 07:44:41 PM »
Allan,
John's comments reflect Randy Smith's instructions to me; the header should NOT be cut, in order to protect the pipe from excessive heat.
Cheers,
Jim
Jim Oliver
AMA 18475
Re: Pipe tuning
« Reply #3 on: June 12, 2009, 11:11:17 AM »
Yep, better to cut the pipe. Keeps the carbon and epoxy further from the heat source.
