  • July 11, 2025, 09:34:34 PM
Author Topic: Pipe setting  (Read 1106 times)
Online Larry Wong
Pipe setting
« on: September 17, 2006, 07:00:34 PM »
What is a good starting lenght fo a pipe on a O S 46 VF ? and what RPM ? ???
Larry
Re: Pipe setting
« Reply #1 on: September 17, 2006, 07:31:23 PM »
Geez........ it's been a while, but no one else has answered, so.........
IIRC, 17 1/4 and about 10,600 with an Eather 3-3/4 pitch 3 blade prop, *about* 12" diameter.  That was with Randy's "old" 40-46 pipe.
I could be off here, but maybe it will spur someone to correct me!   n~
Bill <><
Online Larry Wong
Re: Pipe setting
« Reply #2 on: September 17, 2006, 07:59:31 PM »
Thank Bill I was just setting up the pipe tunnel on my new plane, and I wanted to check if I was in the ball park, it is set at 17 1/4" now so I guess
I can build around it . can go longer if needed.   #^
Larry
Online RandySmith
Re: Pipe setting
« Reply #3 on: September 17, 2006, 08:35:04 PM »
HI larry
You  need to make sure you can get the pipe  out to 18 1\2 inches
Re: Pipe setting
« Reply #4 on: September 18, 2006, 09:53:28 PM »
My OS46VF ended up about 18.5 inches. I'd leave the room.
