Engine basics => Engine set up tips => Topic started by: Larry Wong on September 17, 2006, 07:00:34 PM
Title: Pipe setting
Post by: Larry Wong on September 17, 2006, 07:00:34 PM
What is a good starting lenght fo a pipe on a O S 46 VF ? and what RPM ? ???
Title: Re: Pipe setting
Post by: Bill Little on September 17, 2006, 07:31:23 PM
Geez........ it's been a while, but no one else has answered, so.........
IIRC, 17 1/4 and about 10,600 with an Eather 3-3/4 pitch 3 blade prop, *about* 12" diameter.  That was with Randy's "old" 40-46 pipe.
I could be off here, but maybe it will spur someone to correct me!   n~
Bill <><
Post by: Larry Wong on September 17, 2006, 07:59:31 PM
Thank Bill I was just setting up the pipe tunnel on my new plane, and I wanted to check if I was in the ball park, it is set at 17 1/4" now so I guess
I can build around it . can go longer if needed.   #^
Post by: RandySmith on September 17, 2006, 08:35:04 PM
HI larry
You  need to make sure you can get the pipe  out to 18 1\2 inches
Post by: Randy Powell on September 18, 2006, 09:53:28 PM
My OS46VF ended up about 18.5 inches. I'd leave the room.
