  • June 21, 2025, 07:59:18 PM
Author Topic: Phantom P30 guts  (Read 9366 times)
Re: Phantom P30 guts
« Reply #50 on: January 11, 2013, 12:50:13 PM »
As promised, here is the Vivell 35 running.  It tachs 9470 with a Rev Up 11-4 wood.  It does 9150 on a B-Y&O 10-6.
Fuel is Coleman lantern fuel with 25% Castrol SAE70 m/c oil
In terms of "propwash", it seems to have lots more thrust with the 11" prop
That's not bad performance for a '40s engine.  It probably would do a bit better on glo, but I didn't try glo.
« Reply #51 on: January 11, 2013, 12:53:29 PM »
Floyd, how do you adjust the ignition timing on that without whacking your finger off?
« Reply #52 on: January 11, 2013, 12:57:04 PM »
I start it with the spark timer fully advanced.  It doesn't kick back.  F.C.
« Reply #53 on: January 11, 2013, 01:17:54 PM »
  At 9500ish RPM one might think the power was well past peak. Hence it will go up if you slow it down, hence a larger prop would be expected to work better.
