  • June 19, 2025, 06:26:39 PM
Author Topic: PA engine glow plugs  (Read 1569 times)
Offline Gene O'Keefe
« on: October 26, 2011, 01:12:28 PM »
Randy lists 5 plugs for his engines...I've been using only the Thunderbolt R/C long...anybody using the remaining four
and your results ? ....Enya #3 or #4 / Glo-devil #300 / Merlin / 4 cycle plugs /
Gene O'Keefe
AMA 28386
Offline Balsa Butcher
  • High Desert Flier
Re: PA engine glow plugs
« Reply #1 on: October 26, 2011, 01:57:12 PM »
I have had good luck with the Merlin plug. I think their standard stunt plug is #2005. I order direct or sometime thru Randy.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #2 on: October 26, 2011, 07:05:56 PM »
  I have pretty much only used the Thunderbolt 4-cycle plug for many years now. The R/C plug works OK Ted found that the 4-cycle generally gives a little more "power" and that has been my experience as well.   I ran the Glo-Devil #300 for years in the 40VF, and it works OK in the PA61. The Enya #3 works fine but is no better than the Thunderbolt 4-Cycle and it costs 3x as much (and also has to have the electrode ground down to work with my starter battery). I ran the Merlin for about a day and it ran OK but my battery would not stay attached.
« Reply #3 on: October 26, 2011, 08:35:34 PM »
Another very good plug is the T-Bolt  BIG BORE 2 and 4 cycle, It works very well in many other motors too
« Reply #4 on: October 27, 2011, 09:12:29 AM »
This is what I have been using for the past year or two, I like it.
Derek
« Reply #5 on: October 27, 2011, 12:20:59 PM »
In most PAs I use the T Bolt RC long or Glo Devil in the cool months, and the Big Bore the rest of the year
