Engine basics => Engine set up tips => Topic started by: Gene O'Keefe on October 26, 2011, 01:12:28 PM
Randy lists 5 plugs for his engines...I've been using only the Thunderbolt R/C long...anybody using the remaining four
and your results ? ....Enya #3 or #4 / Glo-devil #300 / Merlin / 4 cycle plugs /
I have had good luck with the Merlin plug. I think their standard stunt plug is #2005. I order direct or sometime thru Randy. 8)
I have pretty much only used the Thunderbolt 4-cycle plug for many years now. The R/C plug works OK Ted found that the 4-cycle generally gives a little more "power" and that has been my experience as well. I ran the Glo-Devil #300 for years in the 40VF, and it works OK in the PA61. The Enya #3 works fine but is no better than the Thunderbolt 4-Cycle and it costs 3x as much (and also has to have the electrode ground down to work with my starter battery). I ran the Merlin for about a day and it ran OK but my battery would not stay attached.
Another very good plug is the T-Bolt BIG BORE 2 and 4 cycle, It works very well in many other motors too
This is what I have been using for the past year or two, I like it.
Derek
In most PAs I use the T Bolt RC long or Glo Devil in the cool months, and the Big Bore the rest of the year
