  • June 21, 2025, 09:36:29 PM
Author Topic: PA 51 Piped Prop Selection  (Read 1300 times)
Offline Walter Johnson
« on: January 23, 2007, 06:44:18 AM »
What would be a good starting point 2 or 3 blade prop for a Tempest II / PA 51 Pipe combo and the advantages or not between 2 or 3 blade and brands available. Thank You Walt y1
Take a spin.....You might like it.
Re: PA 51 Piped Prop Selection
« Reply #1 on: January 23, 2007, 10:45:01 AM »
HI Walt
The Bolly 12.2 x 4.2  2 blade and the Bolly 12 x 4.25  3 blade are the best to start, This is what I use on my 51  and  are  excellent choices.
Both have advantages and disadvantages, just a few  are :
three blades are quieter, the are also a little less prone to wind whip up , and sometimes are more of a constant speed. Two blades are easier to turn, are lighter, cycle faster  4\2  , load the motor less
I can use either with great results, just have a little bit differant setup with the two differant props
« Reply #2 on: January 23, 2007, 12:39:58 PM »
I have personally used the Bolly 12.2X4.2 2 blade on my PA 51 with the pipe as Randy can attest.   He has flowm my plane (a modified Saturn) which is in the mid  50 oz range.  I have not seen a need to go to a 3 blade on that one, yet. ;D
Bill <><
« Reply #3 on: January 24, 2007, 06:42:35 AM »
Thank You Bill and Randy for the suggestions, looks like I will start with a two blade and go from there. The PA 51 I have was bought back in 1996 and was able to purchase it from a friend who decided it was to much at the time for him. He had bought a Bolly two blade then that I have looking at the scribe ID it looks to be a 12.6x3.8 I think a little tough to read. I'll put a little chalk to it and see if it reads better but will purchase a new prop in those numbers above. Thanks All Walt :)
« Reply #4 on: February 22, 2007, 08:40:21 PM »
Hi Walt
The  12.6 x 3.8 is a little flat  but  will work  well  if it is  pitched  up  some, to about  4.2
