  • July 01, 2025, 01:08:16 AM
Author Topic: PA 40  (Read 139 times)
Offline Leandro_Foltran
PA 40
« on: June 29, 2025, 04:05:00 PM »
Hi !
Bought one second hand PA40 from a friend of mine.
It comes with tree head shim on cylinder head:
0.008 inch 0.21mm
00075 inch 0.19mm
0.003 inch 0.07mm
This is ok ?
What”s the standart/initial head shim configuration ?
Leandro
Re: PA 40
« Reply #1 on: Yesterday at 08:09:47 AM »
How was your friend using it? Just try it and see how it runs.
Re: PA 40
« Reply #2 on: Yesterday at 11:06:34 AM »
Hi !
0.008 inch 0.21mm
00075 inch 0.19mm
0.003 inch 0.07mm
This is ok ?
Leandro
   I don't recall what I was using, it was a long time ago, and I was never too happy with my setup. My *guess* is to start with about .023-.025 of piston/head clearance. Even something as beautifully made as a PA, you need to actually measure it, rather than count up gaskets.
    Also, I think your 0.0075 is a nominal .008 - I think there were only ever .003, .005, and .008  gaskets. Measuring to 5/10000s is a tricky business.
