  • July 01, 2025, 03:58:08 AM
Author Topic: PA 75 setup weights  (Read 513 times)
Offline Paul Richardson1
PA 75 setup weights
« on: June 16, 2025, 05:07:47 AM »
Hi All, I'm looking for some details and specifications on the PA 75.
What is the weight of the Engine, header and Pipe. Also how much fuel do you need for 5.5 minutes?
Re: PA 75 setup weights
« Reply #1 on: June 22, 2025, 08:56:34 AM »
1/2 pint fuel tank.
« Last Edit: June 22, 2025, 10:55:33 AM by Motorman »
« Reply #2 on: June 22, 2025, 10:25:31 AM »
   I don't know the weights. I think David F is using about 8.5 ounces of fuel.
   I would highly recommend David's engine article from Stunt News as a reference.
Online Brent Williams
« Reply #3 on: June 25, 2025, 09:54:26 PM »
Craig Beswick is selling his PA75 + Header + Brian Eather tuned pipe setup and kindly provided these measurements.
PA75 Engine: 350 grams, 12.35oz.
Header, Brian Eather tuned pipe and silicone connector: 114.25 grams, 4.03oz.
Total:. 16.38oz.
« Last Edit: June 25, 2025, 10:16:12 PM by Brent Williams »
Online Craig Beswick
« Reply #4 on: June 25, 2025, 11:08:19 PM »
For what it's worth the PA75 Brent refers to came out of a competition Trivial Pursuit, with a purpose built tank and it is 8.5 ounces.
Craig
AUS 87123
"The Ninja"
« Reply #5 on: June 26, 2025, 06:23:11 AM »
Thanks very much guys, appreciate the info 👍
