  • June 19, 2025, 05:21:14 AM
Author Topic: OS46FX Needs Rebuild  (Read 834 times)
« on: April 12, 2018, 03:46:10 PM »
I have a OS46FX in need of new bearings and probably a connecting rod.  I have never "rebuilt" a bearing engine.  Can you do it without special tools?  If so is there someone out there that does this or would I be better served putting the $$$ towards something newer.
Re: OS46FX Needs Rebuild
« Reply #1 on: April 13, 2018, 12:52:45 AM »
Plenty of u toob bulldust on rebuilds / toonin . Cleanliness is a1 first order priority . Not outdoors in Kansas on a windy day .
Surgically clean should be adequate , and wait till the wifes out shopping before you use the oven . a pot of boiling water
usually does the trick , but then theres the dampness to take account off . So Oven Mitt and a receptical are in order .
